Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 04-04-2004, 12:57 AM
Seany B Seany B is offline
Camber with bolts and washers?
Can anyone give me instructions on how to do the rear camber with bolts and washers? (or whatever else)
its for a 91 civic DX
Old 04-04-2004, 12:19 PM
BullShifter's Avatar
Re: Camber with bolts and washers?
http://home.earthlink.net/~civicex95/rearcamber.html
Don't use cheap ass bolts as shown on that site. Spend the money for high grade bolts. Suspension bolts need to be strong.
Old 04-04-2004, 04:41 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Re: Re: Camber with bolts and washers?
Agreed. I did this same "trick" with my rear camber, works good. You must use either case hardened bolts (like what came on the car from the factory), or zinc coated grade-8 or higher bolts, something that AT LEAST meets automotive grade. Grade-8 is automotive grade, something with a higher number will work too if you can find it.
Oh yes, when you put the new bolts on, you MUST coat them completely in thread locker, unless you want them to rattle loose under suspension vibration, which they CAn and WILL do.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 04-14-2004, 02:55 PM
CiV99SnAd CiV99SnAd is offline
my car has severe camber problems in the rear. I now know how to change the camber but i was also wondering if this will affect the way my tires sit in the wheel well. My rear tires sit about a half inch inside the wheel well (verticaly) and if i were to use the washer + bolt trick would my tires still fit inside the wheel well or will the fender come down on top of the tire?
Old 04-14-2004, 11:50 PM
If you have "severe" camber problems I would not suggest this method. Camber kits should be used.
Your tires sit like this now : / \
Correct "street" alignment would be like this | |
If you're using larger wheel/tires with a big drop there might be a rubbing issue. Might need new wheels/tires or have the fenders rolled, hard to say without seeing or knowing specs.
Old 04-15-2004, 01:00 AM
Cali Guy
Hence why I love my Teins. As if ES100 tires aren't tall enough on the sidewall already (due to their design) I had to RAISE my car up slightly when I got the tires installed, I think because I had done the camber trick thing. Unless it's extreme though, it shouldn't be much of a factor, clearnace issues. I know mine wasn't more than 2* off in the first place.
hessemer69 on AIM
Old 04-15-2004, 09:48 AM
My camber is probably off about 2 maybe 3 degrees so I'm rather skeptical about the bolt/washer trick. Does anyone know a place i can find a good camber kit that replaces the lower control arm. i was thinking an Ingals kit but its hard to find one at a good price. Does anyone know of a cheap but place to find these or comparable brands?
Old 04-16-2004, 10:24 AM
bennybenster bennybenster is offline
Send a message via AIM to bennybenster Send a message via Yahoo to bennybenster
Has anyone done this to a 90 crx si?
