Go Back   Automotive Forums Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > Performance
Performance Discussion about performance modifications and issues.
Old 01-09-2002, 04:32 PM
gtr33m gtr33m is offline
Send a message via ICQ to gtr33m
Will a Nismo twin plate clutch from r33 GTR fit an r32 GTR
As above, I've got a Nismo twin plate clutch from r33 GTR which I would like to fit to a r32 GTR. Can anyone tell me if this is possible before I rip the whole thing apart.
Conversely, will a standard r32 GTR clutch go back into the r33 GTR?
Mark
[email protected]
Old 01-09-2002, 04:54 PM
SDUCentral SDUCentral is offline
Maybe!
There was a change from push to pull type clutch in 91/08 with the R32 (I could have that the worng way round)
If the 32 is AFTER 91/08 then yes....it should work ok, if not then it'll be a bit of a mission.
Ray.
AKA R32GTR
Old 01-09-2002, 04:59 PM
It's a 92, but I'll have to check the exact build date.
What about putting the standard 32 GTR clutch back int he 33?
Mark
[email protected]
Old 01-09-2002, 08:57 PM
NISMO23 NISMO23 is offline
It is possible
Is your NISMO clutch a pull or push type? I know that nimso makes the pull type clutches so they will install with no problem. If it is a push type, you will need the "pull to push adapter" before you can install it. It isn't hard at all to install.:smoker:
Old 01-09-2002, 09:24 PM
I don't know if it's the pull or push type. Is there any way of checking without pulling it apart?
The clutch was purchased new for a 96 33 GTR. What would be the standard type?
Mark
[email protected]
Old 01-10-2002, 02:09 AM
wld33 wld33 is offline
if you don't end up putting it in i would buy it of you
cheers
michael
you want time buy the magazine
Old 01-12-2002, 04:01 AM
turbogtst turbogtst is offline
Mark
They will interchange but you need to interchange clutch operating mechanisms for both eg slave cylinders, throw out bearing, pivot shaft and front gearbox throw out bearing runner, or swap the 2 gearboxes completly over that is easier.
Greg
Old 01-13-2002, 03:12 PM
Unhappy
Sounds as though it's not worth the effort.
My main gripe with the Nismo is the life of it and the cost of rebuilding it. I'm lucky to get eight months out of the clutch, and the plates can't be re bonded.
If anyone know anyone in Oz that can rebond the plates, let me know.
Mark
[email protected]
Old 01-13-2002, 03:35 PM
Get rid of it and get an OS giken they are cheap to rebuid.
OS GIKEN twin plate clutch primo Classifieds 1 08-31-2004 03:34 AM
Where to buy Nismo Twin Plate Clutch? Guycali Performance 1 04-22-2004 03:24 PM
*TWIN-PLATE Clutch Questions, HELP!!! mister2 Engineering/ Technical 1 11-02-2002 01:42 PM
I've got a Nismo twin plate button clutch to swap for standard 33 gtr clutch. gtr33m Classifieds 3 01-16-2002 05:52 PM
Nismo twin plate button clutch for standard 33 gtr clutch gtr33m Classifieds 0 01-15-2002 04:05 AM
