Old 04-03-2004, 08:51 PM
eswaroop eswaroop is offline
dirty o2 (oxygen sensor) ? Will it read lean or rich?
Hi,
If my o2 sensor is dirty, (clogged by soot) will it read lean or rich? I am guessing it will read lean even if it is rich, but anyone who knows for sure?
Thanks
es
Old 04-03-2004, 10:36 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: dirty o2 (oxygen sensor) ? Will it read lean or rich?
yes it would most likely read lean, depends on exactly what is wrong with it/ how it is clogged.
Why do you want to know?
Old 04-03-2004, 11:28 PM
Re: Re: dirty o2 (oxygen sensor) ? Will it read lean or rich?
Well, I had a valve adjustment done at a dealer, it was not done properly, now the car (99 accord EX 4 cyl) seems to be running rich, coz the spark plugs are getting sooty, exhaust is sooty and mileage and power are drastically lower than before. I am guessing that because of the incorrect adjustment, the engine was burning badly and that clogged the o2 sensor, now even though the valves are adjusted properly, because of a dirty sensor, the ecu is burning my engine rich?
Is there a way to clean the sensor? and what is the easiest way to check if the 02 sensor is faulty?
Thanks,
es
