Old 04-03-2004, 08:30 PM
stegoman stegoman is offline
Unhappy Heater not working, why?
The heater on my 1997 Lumina does not heat up. The AC works very well. Could the control nob switch be broken, is there a fuse that could be blown, is there an elecrical motor that opens the heater valve or could the car just run to cool to heat it up? I welcome all replies. Thank you.
Old 04-05-2004, 05:24 PM
Skillet's Avatar
Skillet Skillet is offline
You could be low on engine coolant or you could have a stuck thermostat. Did you just recently flush your cooling system?
Old 04-05-2004, 09:09 PM
Coolant up to levels, thermostat appears to open as the temp guage registers fluctuations in temperature. Just purchased vehicle and cooling system is clean. Thanks for the reply.
Old 04-29-2004, 11:25 AM
kevinb70 kevinb70 is offline
Send a message via AIM to kevinb70 Send a message via Yahoo to kevinb70
Re: Heater not working, why?
vacuum line controlling the air door?
Old 04-29-2004, 09:28 PM
thought about this afterwards... maybe you have the same problem with the dexcool causing corrosion and sludge deposits in your cooling system... perhaps the heater core occasionally has blockages due to sludge? You say your coolant is clear now... but was it recently replaced?
or maybe you need to purge the air out of your radiator? there are two bleeders on your engine.
