Old 04-03-2004, 06:04 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Gasket
Well I have a valvecover leak in the back right corner.
So before I change it, I was just wondering should I use OEM gaskets, or will the autozone/pepboys ones do just fine.
I will be changing the spark plug gaskets and the valvecover gasket.
Thanks
For Sale 98 Eclipse GS, 5 spd
Old 04-03-2004, 07:34 PM
dupeto_e's Avatar
dupeto_e dupeto_e is offline
Re: Gasket
i just put regular one(autozone/discountatoparts) and is just fine(+spark plugs gaskets).
Old 04-03-2004, 09:27 PM
Talon007's Avatar
Talon007 Talon007 is offline
Send a message via MSN to Talon007
Re: Gasket
I would use an OE one, they are a tad thicker and fit tighter in the valve cover.
Chris Clark
www.Talon007.com
1990 Eagle Talon TSi AWD - In Progress
1993 Eagle Talon TSi AWD - Parts Car
1990 Eagle Talon ESi - Sold
1-800-VFAQ - Bookmark it, read it, use it
Old 04-04-2004, 03:05 PM
ashah000's Avatar
Re: Gasket
How about using silicon sealant with it, I have heard that sometimes it causes leaks, but have also heard its good.
Old 04-04-2004, 03:09 PM
Talon007's Avatar
Re: Gasket
Only use RTV on the half moon
Chris Clark
www.Talon007.com
Old 04-04-2004, 03:35 PM
ashah000's Avatar
Re: Gasket
Half moon?
Does my car have that, its a 98 gs.
Well I found this, do these places look alright.
http://www.2gnt.com/www/corbin/vc.html
(the last picture)
Old 04-04-2004, 07:11 PM
Talon007's Avatar
Re: Gasket
Nevermind the half moon comment, I assumed you had a 4G63.
Chris Clark
www.Talon007.com
Old 04-05-2004, 02:19 PM
anarchy1114's Avatar
anarchy1114 anarchy1114 is offline
Send a message via AIM to anarchy1114 Send a message via MSN to anarchy1114 Send a message via Yahoo to anarchy1114
i just did this about a month ago. its fairly easy but for sure go with the oem gaskets. make sure you get all 5 pieces. each one for the spark plugs and one for the valve cover. and yes that page looks right. i used chiltons for my repair and it gives `you the specific tourqes you need for the vavle cover.
plus if you have got oil in the spark plug wells than i would suggest also replacing both your spark plugs and the wires.
good luck with the repair tho. and feel free to pm me or hit me up on my messenger if you need any help.
oh yea don't break the positive pressure line on the engine like i did.
If it has tits or tires it will give you problems, but atleast you can fix the problems with the tires
2007 Trailblazer - stock
97 GS-T -> lots of mods
98 GS ->total loss, now being parted out
