Start the car pull away and for the first 4 to 7 times I step on the brake and I get a loud rattle (sounds like front right wheel well) and a lot of hard and slow kick back from the abs pusling. Then the ABS light goes out and the standard brakes kick in and I have no problem. I this something I need to worry about??
Re: Massive ABS problems!! 91 Accord SE Please Help
Well I would definantly check out your brakes system and make sure it is all in order. Have someone competent check your fluid, your pads, calipers, rotors. Make sure everything is still attached...Also if you have dashlights coming on, take it to Autozone, they will read the error codes on your ECU and tell you the exact code numbers, then you can post them here so we can tell you exactly what is wrong.
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
