Old 04-02-2004, 11:02 PM
thunderbird muscle's Avatar
thunderbird muscle thunderbird muscle is offline
4.6 performance options
What is the best way to go with the 4.6 in a 95 Thunderbird(same as 96 mustang)
I just want something to eat local ricers. So would I just want a chipj or do I need a lot of work done to the motor, you know cams, heads, etc.
Thanks for the help!!!!!!!!
Old 04-02-2004, 11:15 PM
RocketStang911 RocketStang911 is offline
Re: 4.6 performance options
well,if your car is stock you don't really want a chip.To beat some ricers you probably only need some bolt on's if you don't already have any.
Old 04-03-2004, 10:14 AM
ShiftedReality ShiftedReality is offline
96 TBird
my friend has a 96 Tbird with an 4.6. from what i've heard the cars weigh a lot for the amount of hp they produce. bolt ons are a def. well depending on what you want to do with it.
good luck
Old 04-07-2004, 11:04 PM
Thanks
The Tbirds are heavy, but they still pack a little punch and will still knock you into the back of your seat when you get on it.
I have an Air Intake, Ram air hood, (waiting on my shift kit to arrive),and a nice set of tires to hold to the ground what do I need next?
Thanks I really do appreciate the help.
Old 04-08-2004, 12:05 PM
Some gears and a torque converter
and maybe exhaust.
You said your car will knock you in the back of your seat when you get on it.After thease mods,It'll pull you through the seat.
Old 04-08-2004, 08:33 PM
already done exhaust (straight pipes baby). Will a low stall speed torque converter take away from the top speed. And what kind of gears.
Its an automatic and is to hard(expensive) to convert to a manual so what gears do you suggest I use.
Old 04-08-2004, 09:05 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
Re: Re: 4.6 performance options
it's a hell of a lot easier to convert from auto to manual than the other way around. cost of the tranny, time under the car to modify the x-member location, cost of the clutch/flywheel assy., cost of the clutch pedal assembly and cable/cylinders+lines. plus install time for that. to convert to auto you often have to add a computer for it, or replace the main engine computer. gotta replace the radiator. among other things. and there are always difficulties you don't see that will completely screw you over if you're not ready for them.
a low-stall converter makes no sense... mod motors don't produce torque till slightly higher RPMs than an average 5.0, so they need to rev higher to launch. you should probably get about a 3500-4000 stall deal. and it won't affect your top end at all.
i'm not too sure you know exactly what a torque converter does... i'll be happy to explain if need be.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 04-08-2004, 10:22 PM
Get 3:73 gears if you do alot of hwy driving.If you drive mostly in the city go with 4:10's!Trust me you'll be happy with them.
Old 04-09-2004, 07:52 PM
Thanks
~not to sound condesending but i know what the Tbirds can do. my friend owns a 96 Tbird with hella mods. he doesnt run strip but does road course. here are a few of the mods.
forged crank, rods, pistons (believe JE)
aluminium 4.6 block
port and polished cobra heads
aluminium intake ( looks like the Bullit intake but an older version?)
vortec supercharger running 13 lbs of boost
msd ignition
converted from AOD to 5 spd
cobra disk brakes
eibach coilover suspension
flowmaster exhaust
subframe connectors ( kenny brown custom )
super street cage ( kenny brown - chassis stiffener)
no rear seat ( weight reduction )
recaro race seats w/ 5 pt. harness
moda rims w/ kuhmo tires
unsure if the 90's model tbird comes with IRS?
producing somewhere about 400rwhp. not sure about torque.
~in any case those are the mods that i can remember. beautiful cars when worked corretly. unfortunately i dont have near as much money as he does to drop into a car just yet. ( its not a daily driver lol )
Old 04-10-2004, 03:23 AM
Bray Hill Bray Hill is offline
His car sounds nice and this is a bit off subject. I just wanted to warn everyone to stay away from the eibach pro-kit spring and any other progressive rate spring on the market, that is, if you're into road racing.
87 300zx turbo (autoxer)
96 thunderbird
94 honda cbr 600 (track day bike)
82 suzuki gs 1100
76 kawasaki kz 650
Old 04-11-2004, 06:12 PM
~the company has gone downhill from what i've heard. most progressive springs dont match up out of the box. they come out to different ratios. however, the set he has on it was put on years ago. he built it up in the mid-late 90's.
~what would you suggest for coilovers? lol , not to change the subject from the 4.6 performance.
Old 04-11-2004, 06:33 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
hm.. I was gonna go with the eibach pro-kit spring set. Oh well...
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 07-14-2004, 12:57 AM
suspension tecniques,(spelling ?).
96 thunderbird
82 suzuki gs 1100
76 kawasaki kz 650
Old 07-14-2004, 01:34 PM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
PI heads, and a Bullitt intake are very worth looking into.
For quick and cheap, gears and chuck some weight. You can always build your own cold air induction with a K&N filter on it. Make sure your exhaust is free-flowing, pretty standard stuff. I know a guy who's trying to sell a timing adjuster, I can ask how much he wants....
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
