Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 04-02-2004, 10:42 PM
mrsjewroll mrsjewroll is offline
Question Cooling Fan Not Turning On, Car Running Hot!!!
I Have Replaced The Motor For Myfan That Cools Off My Radiator But The Fan Is Still Not Turning On. What Am I To Do?
Old 04-03-2004, 08:59 AM
justinwebb justinwebb is offline
Send a message via AIM to justinwebb
Re: Cooling Fan Not Turning On, Car Running Hot!!!
have you checked the sensor that tells the fan when to turn on when it gets to hot?
Old 04-04-2004, 02:44 PM
Question Re: Re: Cooling Fan Not Turning On, Car Running Hot!!!
JUSTINWEBB THANKS FOR YOU REPLY. TO ANSWER YOUR QUESTION, NO BECAUSE I HAVE NO IDEA WHERE THE SENSOR IS LOCATED. CAN YOU TELL ME WHERE TO FIND IT? I DID NOTICE THAT I HAVE TWO FANS BUT ONE IS STILL ONLY WORKING. THE ONE THAT I REPLACED STILL IS TURNING ON
Old 04-06-2004, 12:16 AM
qwex qwex is offline
if you have 2 fans one is usually on when the a/c is running. try turning that on and checking. also are the hoses hot when the over heating happens. if only warm may be themostat or water pump.
Old 04-07-2004, 11:04 PM
cdman3d cdman3d is offline
My guess would be the thermostat is stuck closed, replace that (only about 10 bucks) You could also look into getting a lower temperature thermostat which would keep your engine cooler than the OEM thermostat. Good luck!
