Legacy OEM Stereo
I have a 1995 Legacy AWD L Wagon. It has the OEM am/fm cassette, with a cubby hole under it. I was wondering if the OEM am/fm cassette/indash cd players from Legacys that are 1996-1999 will fit my dash if I remove the am/fm cassette player/cubby hole. This would be a slick upgrade if they fit. Anyone try this or know any details, about possible necessary brackets, or??????
Thanks in advance for any responses, John |
Re: Legacy OEM Stereo
I'd just do it anyways all too easy to put it back as it was if it doens't fit, but i'm sure they have to follow some standard, every car i've owned i have removed the OEM stereo and installed a aftermarket one. You could always just build a new cradle.
Cheers
I Own a: 1989 Subaru Legacy RS 2.2 Stroker Kit Forgies 2.5 Exhaust w/ RPS Muffler LambdaLink KnockLink Heavy Clutch Strengthened Gear Set No 4wd dyno for MILES!! Standard Everything else |
Im pretty sure they will fit. An aftermarket stereo fit in my 98...
Yes, definately, the cubby hole will come out with the stereo if you like - use a double din replacement if you dont need the cubby hole. There is a nice replacement option typically available on ebay - in-dash 6cd /am/fm Subaru factory replacement beleive it or not for $169 USD. I have one with the subaru 120watt factory sub from a wrx - everything wires in with factory harnesses (very clean), and flat ROCKS my 96 wagon, grab the factory tweeters also if u are on ebay - 15 minute installation, all legs are prewired to accept them. You cant go wrong with these components
Factory tweeter closeout
While doing your stereo - the factory is closing out tweeters that replace the flat panel behind each side mirror for $15 for the entire kit. And they wire right into the harness that is wire-tied up behind the door panel.
Yes, and if you buy them, you can (carefully) remove the tweeter from the housing and replace them with a higher powered (~200w) 3/4 inch tweeter for a very nice installation - I did it with mine and the difference is amazing.
96legwag
Are you saying that that perception of mine that the factory tweeter may distort just a little - like it isn't real clean - is not just my own illusion - that it needs something a lot better? |
New to the forum, How do i remove the factory stereo in a 95 legacy ls. Thanks for any help.
Thank you very much
