Old 04-02-2004, 03:34 PM
JoelD JoelD is offline
Steering Noise when turning
99 Ford Windstar,70000 miles on clock has noise coming from left side when ever you turn steering wheel,Can,t tell if its coming from inner or outer tie rod or lower ball joint or the steering gear its self.Anyone had this problem and has a fix??
Old 04-02-2004, 04:23 PM
Seizer's Avatar
Seizer Seizer is offline
Re: Steering Noise when turning
First guess is CV joint. When you turn are you turning right or left? Is it a whine or a clicking noise?
Old 04-02-2004, 07:40 PM
The noise is present sitting still in the drive way.I think that rules out a cv joint.I intend to disconnect the outer tierod and see if i have a noise in the spendle ball joint when the spendle is moved back and forth
Old 04-02-2004, 08:08 PM
rodeo02 rodeo02 is offline
Sounds like one of the "sealed for life" ball joints or tie rod ends has run dry and is making noise when they rotate. You can try to grease them by using one of those grease gun needles, where you poke the needle thru the boot & give it a shot of grease. Only other option is replace the b-joint or t-rod end. Try to use aftermarket ones with grease fittings.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 04-03-2004, 07:24 AM
lewisnc100 lewisnc100 is offline
I used a grease needle on both my outer tie-rod ends and ball joints a few weeks back and it completely eliminated the noise.
Old 04-03-2004, 11:17 AM
busboy4 busboy4 is offline
Noise
Hi Joel
My '96 had a popping noise during cornering, start-stop and also when stopped and turning wheel L&R. In my case is was the subframe bushings. I changed all 4 and things are quiet.
Mel
Old 04-03-2004, 11:31 AM
Re: Noise
Originally Posted by busboy4
Hi Joel
Mel
Good info. Thanks Mel!
Joel
Old 04-03-2004, 04:19 PM
Problem solved,Right ,(passenger side) outside tie rod was dry.metal to metal and the noise was amplified thru out the steering system. Replaced tie rod with a greaseable tie rod and adjusted toe. slightly off with new part.Thanks for everyones help. Total cost $27.00 and my free labor
