Old 04-02-2004, 04:01 PM
juma33 juma33 is offline
2004 piston slap
any 2004's out there with piston slap evident??
that $3500 cash back right now looks good but not if the piston slap is still around.
juma
Old 04-03-2004, 06:36 PM
phoenixzc phoenixzc is offline
I have an 04 with the 5.3 and 9,000 miles no slap what so ever
Old 04-05-2004, 10:21 AM
CSI-LEVEL3 CSI-LEVEL3 is offline
Re: 2004 piston slap
I Have A 2004 With The 4.8, No Piston Slap. Good Luck
Old 04-05-2004, 12:48 PM
brumleveb brumleveb is offline
I heard from someone (not a salesman) that GM had fixed that problem for 2004. I've got a 2004 2500HD w/6.0 liter with no slap.
Old 04-05-2004, 09:53 PM
BigblockChevelle BigblockChevelle is offline
Thumbs up
I have a 04 1500 with 3500 miles no slap and great gas milage! Go out and get one! Mine is the 4.8 by the way
Old 04-06-2004, 12:33 AM
chevytrucks92's Avatar
chevytrucks92 chevytrucks92 is offline
My Grand Dad has an 04 with the 5.3, just had its first oil change and no slap. He also had a 2000, traded it to the 04, it had 36,000 miles and the 5.3 and no slap either, lol.
**1966 Chevy II**
355 SBC, Turbo 400, 5.13 gear, IHRA Certified to 8.50 in the 1/4
Last Race (10-6-07) So its been awhile...
Dial: 6.77, RT: -.0001, 60': 1.4360, 1/8th: 6.7942 @ 100.65 mph
Fastest Pass of '07 (10-6-07)
60': 1.4360, 330': 4.3453, 1/8th: 6.7942 @ 100.65 mph
25 and in BIG TIME Debt Crew member #2
Deuce's Wild Racing: Take a Ride on the WILD SIDE
Old 04-06-2004, 11:11 AM
I had heard that the problem was particularly bad in two years, but could remember whether it was '01/'02 or '02/'03. Either way, the problem is supposed to be fixed now. It may have been fixed for '03.
Old 04-06-2004, 12:49 PM
tidalcock tidalcock is offline
Mine is an '01 with a 4.8 and 50k. No slap noises here.
Old 04-07-2004, 01:05 AM
desertmike1 desertmike1 is offline
I think the term "piston slap" has been greatly abused!
If you Rap an engine with slap, you get a quick multible tick during decel, most people experience a tick during idle.
My 1998 3.1 Malibu piston slap problem turned out to be a lazy harmless lifter.
Just something to think about!
-Mike
Old 04-07-2004, 03:27 PM
dpatrick dpatrick is offline
I have a 2000 2500 with 6.0ltr and I have piston slap. The truck has 120,000 kms. It seems to have gottin worse since changing over to synthetic oil. I bought the truck used with an extended warranty so I will be getting a compression check before the warranty runs out. I will start the motor for about a minute before driving as I don't like excelerating when the motor is knocking. It seems if you give it a chance to warm up there is less knocking. Other than that the engine runs good. Doesn't burn oil and power is good. gets about 18mpg and 11mpg pulling the rv.
2000 Chevy 2500 6.0ltr 4.10 rear
Old 06-15-2004, 05:07 AM
dirtbike661 dirtbike661 is offline
i got a 2004 Silverado 2500 6.0 gas engine.. I get that noise when it starts cold.. .and sometimes when it's warm and idle. I hear a slight pinging noise in the engine.
Old 06-15-2004, 02:56 PM
Redneck_Cadillac's Avatar
Redneck_Cadillac Redneck_Cadillac is offline
juma
piston slappage ended in 2002. 2003 and newer, the problem was corrected......
I haven't, nor ever will claim to know everything about cars..... but a big f*cking hammer can fix most problems.....
Old 06-15-2004, 06:10 PM
Re: Re: 2004 piston slap
DPatrick... your problem is typical GM piston slap. the piston is loose in the bore (to simplify) and makes noise when cold. when the piston and cylinder heat up, they expand, making it a tighter fit, and quieter.
changing to synthetic oil will make it worse, since although synthetic protects better, it's thinner by nature. oil packed under your rings helps quiet the piston in the cylinder. make the oil thinner, and you allow the piston to "pivot" more in the cylinder, making the noise worse.....
reports are conflicting as to whether or not the problem will cause long term damage or not....... i had a chrysler that i drove (318 cid) for 173, 000 miles with piston slap, and it never became anything more than annoying.....
Old 06-17-2004, 10:00 PM
jerrylittle jerrylittle is offline
Angry Re: 2004 piston slap
juma
Yes I have a 98 with a brand new motor and I have piston slap.
Old 06-19-2004, 01:35 PM
if new, check production date on engine.
if reman, they're rebuilt by independant shops, contracted by GM.............not by the factory........
....... warranty?????
