Old 04-02-2004, 02:11 PM
lady26 lady26 is offline
Unhappy my 1998 chevy cavalier won't start
I have a 1998 Chevy Cavalier. My husband recently put a water pump in it his self is there any way you could let me know why it wont start now?
Old 04-02-2004, 07:41 PM
C_Sephiroth's Avatar
C_Sephiroth C_Sephiroth is offline
Send a message via AIM to C_Sephiroth
Re: my 1998 chevy cavalier won't start
Does it Crank over? Does it crank slow?Does it do anything? Clicking noise?
Homer: No T.V. No Beer makes Homer go... Something Something or another..............
Marge: Go Crazy......
Homer: Don't mind if I do.....muahahahahahbwauauauauauauau
Old 04-02-2004, 09:28 PM
no it doesnt do anything... it acts like the battery is dead or something but its a new battery.? I havent got a clue to what went wrong
Old 04-03-2004, 11:09 AM
bigdaveangell bigdaveangell is offline
sounds like a problem with the starter. Tap on the starter with a hammer and then try to start it. If it starts you will have to replace the starter
Old 04-05-2004, 11:09 AM
sweetwhiteCAV sweetwhiteCAV is offline
Send a message via AIM to sweetwhiteCAV Send a message via Yahoo to sweetwhiteCAV
If it was the starter, there would be some sort of noise, like a grinding or at worst a clicking sound. If theres no sound at all, I would guess that it definetly a battery problem. How long before this problem, did your husband put the water pump on?
Old 04-05-2004, 03:26 PM
most likely a coroded battery cable or terminals or even the battery itself. Do you have a dvom to test it with. If its below about 10 volts you will have to charge it
Old 04-05-2004, 09:35 PM
Okay let me see if I have this right. Do you have any lights or anything? do any of the acessories work?
Old 11-16-2014, 07:32 AM
trez260 trez260 is offline
my 98 cavalier is having the same issue where it will not start. it turns very slowly and occasionally stutters as if it wants to start, but it doesn't start.
backstory
first the belt broke, replace belt and idle pulley
then it ran hot from lack of coolant, refilled coolant, replaced thermostat.
since then i noticed it cranks very slow, i thought it was battery, replaced battery and it still cranks slow and not starting.
not sure where to look next. starter?
*i replied here because i'm not able to start a new thread/post
i'd appreciate all suggestions.
thank you.
Old 11-16-2014, 11:12 AM
Jmrec100's Avatar
Jmrec100 Jmrec100 is offline
Hey Trez,
Check the thread just above this one. It's 1999 but should be similar issue. This is too old thread to use to reply etc
Before just go changing out parts, have them tested. Local auto parts should be able to test starters for you. As for new battery, was the old one tested first?
