heated seat
my heated seat does not work on the driver's side only-passenger's side works fine....any suggetions?
Re: heated seat
Get a multimeter out and check for continuity in the wires. The wires going through the door hinges seem to have breakage/shorting issues. The elements in the seat itself could have taken a beating from the drivers posterior too. Either way they both get a lot more wear and movement than the passenger side.
Re: Re: heated seat
[quote=dsatt12]Get a multimeter out and check for continuity in the wires. The wires going through the door hinges seem to have breakage/shorting issues. The elements in the seat itself could have taken a beating from the drivers posterior too. Either way they both get a lot more wear and movement than the passenger side.[/QUOTE
Thanks. |
Re: Re: heated seat
Re: heated seat
I think you can find a multimeter at any hardware store in the electrical dept. I can't imagine it would be to much, its not like a scantool or anything.
1997 Aurora "Aurora Snow" 250++HP 4.0L Modified Aurora V8 w/Autobahn Performance On Deck: RSM intake, RSM 80mm TB ![]() Administrator, www.oldsmobileforums.com Administrator,Aurora Club of North America Administrator, www.bonnevilleclub.com Adminstrator, www.ontariobonnevilleclub.com Coming Soon |
Re: Re: heated seat
I think I paid $10 for my (crappy) toolbox one. All you really need though is preferably one that checks continuity- it will beep if a circuit is intact between your two probes. If you can't find a cheapo that does that, just use the resistance function. It's checking the same thing internally, just doesn't beep. Look for something other than infinite resistance.
