Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 04-02-2004, 07:08 AM
roloholo roloholo is offline
Unhappy Big Problem w/ RUBBING...Need Expert Help !
Alrite, I have a 01 accord. I put 17" rims, offset : 40+mm & size: 17x7 w/ yokohama tires : 225/45/17. My back tires rub like crazy when I have a person sitting in the back over little ditches and turns (and its at stock height). Basically it seems like my wheel is sticking out just a take bit wider than my fenders. I have tried bending in my fender with a baseball bat and also took my car to an auto shop to get the fender lip shaved off...but with no luck it still fucking rubs....its freaking annoying...I need some expert advise on this situation of mine..what else can I do ? is there a specfic offset i should have for my car? if so, whats the offset? new rims? new tires? does camber kit work? your help/suggestions are appreciated.
Old 04-02-2004, 09:34 AM
chucksnee chucksnee is offline
I think the 225 are just to wide go down to a 215 and the rubbing should go away!
Old 04-02-2004, 03:16 PM
PhiberOptik's Avatar
PhiberOptik PhiberOptik is offline
Re: Big Problem w/ RUBBING...Need Expert Help !
I wouldnt go bigger than 205
99 Civic EX
Si Spoiler
Type R mesh grill
Old 04-08-2004, 09:42 PM
Volume_Civics Volume_Civics is offline
Your car was designed for the stock wheel size. By putting in bigger rims you get less clearance( thats why you are bottoming out).You can either get a smaller wheel set or you can get better suspension. Stiffer springs etc or coil overs. Or go on a diet.
86 buick lesabre estate wagon with 70's olds 455 big block engine in need of help kcbuechler LeSabre 29 06-26-2012 10:21 AM
need expert help for over-heating problem dixienew1052 General Discussion 7 07-31-2008 10:02 AM
I have a Big problem and need some serious help??? Talon5 Off-Topic 1 09-17-2004 10:06 PM
need experts help with this system!!!! likitea Car Audio 9 06-14-2004 11:09 PM
need expert help ersatz0906 Tires and Wheels 3 08-27-2003 09:38 PM
