Old 04-01-2004, 07:43 PM
emopunksucksnuts emopunksucksnuts is offline
Send a message via AIM to emopunksucksnuts
Help me with my 70 chevelle ss
Alright....im 18, i am just getting my first car....and i have always loved muscle cars....im thinking about getting a 70' chevelle ss. That has been my dream car forever. But what i wanted to know, is if a 502 big block will fit under the stock hood of my dream car....i would appreciate any tips for restoring cars, cuz im a noob, and i dont have lots of money...thanks a lot everyone....
nick
Old 04-01-2004, 08:15 PM
GTR2b's Avatar
GTR2b GTR2b is offline
Re: Help me with my 70 chevelle ss
The engine will fit fine. The 502 is a bored-over 454 and the 454 was one of engines available in the '70 Chevelle as with the more common, 396 which has the same block as well.
Now finding an affordable '70 SS with the 454 that is in any kind of decent shape is near impossible so here is what I would recommend.
Look for a Chevelle with the 396 and the automatic, they're much cheaper and then you can take the money that you saved and get a 454 from a truck around the same year and drop it right in.
It's a very simple and straight forward process.
Old 04-02-2004, 07:14 AM
Now is a 502 exert more hp than a 454?
Old 04-02-2004, 07:16 AM
And also, if i get a 396 with an automatic, wouldnt i have to replace the transmission if i wanted it in manual?
Old 04-02-2004, 10:36 PM
kratefan kratefan is offline
Re: Re: Help me with my 70 chevelle ss
You'd have to get a new tranny. If you can find one with a manual, you'd want to make sure it could handle the extra HP of the 454 or 502. The 454 would be easier and cheaper to find and buy. There are a lot of 454's out there. I'm not sure of the 502 since it is mainly a crate motor.
Jeff
Old 04-20-2004, 01:05 AM
GearHead1214 GearHead1214 is offline
personally i wouldnt get a 502.. the 454 is a better street motor. it has a shoter stroke for the huge bore that the 502 needs which gives more torque. plus the 502 will be very expensive and need and expertiece to build a really fast one. plus it would give u more power than u even want and waste more gas. a 454 is a fine decision and if u want a manual then yes u will need some modifications. all u need to do is cut a hole in the floor, the brake pedal needs to be changed since the clutch mounts off the brake pedal but thanks to good ol chevy the brake pedal with or without the clutch mounts exactly the same so there are no worries, u just need to get the right one. also u will need to get the linkages for the clutch and it will need a new starter since a flywheel and a flexplate uses dif starters. it would save u trouble if u just get a chevelle that has a stick in it or did at one time, but gtr2b was right the auto will be much cheaper but is it worth the work......??
-GearHead
Old 04-22-2004, 08:36 AM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Why take out the 396!? That was a very good engine, you can get just as much out of a 396 than a 502. And the time it took him to get the 502, his 396 could have just as much hp as the 502 stock.
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 04-22-2004, 08:39 AM
911S_TARGA_RSR 911S_TARGA_RSR is offline
Muscle cars need automatics.
911 Super Targa RSR
[Dual Flow Intake][Twin Turbo][Larger List to Come]
Old 04-22-2004, 08:54 AM
actually z28, im sorry to disagree, but the 396 is one of the slowest revving big blocks made. in the 60's when chevy put them in the SS's they were nicknamed Super Sled for years becuase it was just a heavy aengine without enough power to handle itself, do not go witht the 396. now im not sayin its entirely a slow engine, but u would be more happy with a 454 and if u can afford it, the 502. and personally i think a muscle car isnt a muscle car until its equipped with a stick, it just makes the drive even more fun, but were all entitled to our opinion..
-GearHead
Old 04-22-2004, 01:14 PM
68chevelle 68chevelle is offline
Send a message via AIM to 68chevelle
not to mention 396 parts are starting to become harder to find and dollar for dollar it will probably be cheaper to build a 454 over a 396.
Old 04-22-2004, 05:32 PM
-Josh-'s Avatar
I stand corrected, probably why a lot of them got bored out to 427, and completely rebuilt. I forgot they are getting harder to find, that's why i was told not to get one for my 66 Chevelle i'm restoring.
AF User Guidelines
Old 04-25-2004, 10:51 PM
Tomsriv Tomsriv is offline
I think a better idea would be to find a Chevelle with a good body and interior and don't worry about the motor for now. Save up and build a wicked small block or build a 454 in your garage while you cruise with the stock motor. Stick shift cars usually cost 3-5k more and are hard to find. A stick conversion will cost about 2-5k. Most of the cost is in buying a manual trans that will hold the torque of a big block
Old 05-09-2004, 12:42 AM
musclecarfanatic musclecarfanatic is offline
Your right, buy the chevelle ss without the motor and trans if possible, its cheaper. also try and find a chevelle ss that has some rust and some interior problems (only if you feel like restoring it, it would be cheaper and more affordable for you), a bit of advice, if you are looking into going this direction of finding one with rust and maybe some interior problems, just make sure the quarter panels are in good shape because they are a bitch to replace. it all depends on what you want and what you can afford. iam currently looking for a 60's camaro, but the problemS im running into is that they are hard to find and are very pricey for a decent one in good condition (no rust, etc). i dont know about you but i want to do a frame off restoration and build my 454 im gunna put into it, and since i want to do this, it makes the price of the camaro a hell of a lot cheaper because i dont need the engine or transmission, im fine with rust (cept quarter panels), and im fine with interior work. i do highly recommend you to find a chevelle ss taht needs restoration and with no engine or trans. its just alot easier and cheaper to find and afford since us teenagers are not made of money.
Old 05-09-2004, 02:36 AM
i agree with ya musclecarfanatic as far as getting one with no engine and trans, i mean if your going to replace it anyway, why get one. they are actualy alot cheeper with no engine and trans, usualy. but like me i will get it either way. i have 3 engines sitting around right now. its always good to have something to tinker with. oh yeah, just a head up, you know the camaro was only made for the last 3 years in the 60 right? thats one reason they are hard to find. they didnt hit the market until 67. one of these days i want to get my hands on a first gen camaro. but like you said they are hard to find for a reasonable price. well atleast what i concider reasonabl. but there are lots of parts for them on the market. not used parts but many many companys cary and manufacture parts for them.
Old 05-18-2004, 03:24 PM
Murray B. Murray B. is offline
Originally Posted by GearHead1214
...they were nicknamed Super Sled for years...-GearHead
I know that the jargon of those times is hard but there was nothing wrong with a "sled'. The term comes from rocket sled. You are probably confusing it with the term "boat" as in a stone boat.
The 375 H.P. 396 is legend and already a crazy powerful engine for a Chevelle. A high output 454 (>400 H.P.) is crazy squared. If that is not good enough then the 502 would not be much better and I strongly recommend the Allison V1710. There are lots of them still in mothballs and they are real motors as opposed to these dinky toys of which you speak.
Why settle for only three digit horsepower in something as big as a Chevelle when four digit is so readily available? Think outside the box.
Help with my 1990 z32 na aaanthony 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 0 01-08-2011 01:24 PM
i need help with ideas for increasing HP on my 70' chevelle SS lordoftheoctagon Chevelle 4 09-01-2010 12:43 PM
Help with new car audio; Cade.Garrett Car Audio 2 07-02-2009 12:32 PM
Help with gauge cluster pin location on 70 Chevelle SS northput21 Chevelle 1 02-20-2007 01:51 PM
1967 chevelle help with headers!!! gride29 Chevelle 4 10-15-2004 10:35 AM
