Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 04-01-2004, 04:53 PM
Raydee Raydee is offline
Send a message via AIM to Raydee
1994 Olds Cutlass Supreme problem
My Cutlass(3100 SFI) is having problems once it shifts into Overdrive. It seems like it is studdering under the load. It will also do it after it is hot and I am going up hills or loading the engine up. It almost seems like a miss or something. Could the coil packs be bad? I was told not to get aftermarket ones and that the OEM are the best. Anybody have any experience with this?
Old 06-05-2004, 10:49 PM
mrcutssupreme mrcutssupreme is offline
Send a message via AIM to mrcutssupreme
Re: 1994 Olds Cutlass Supreme problem
Don't worry I have the same exact car and that same exact problem. Are you talking about once it's in overdrive and you accelerate just enough to where it stays in overdrive and doens't drop a gear, the whole car shakes? if so, get your manifold cleaned out. We took it to the dealer and there was an unbeleivable amount of carbon build up, sure it cost about $300, but man was it worth it, she purrs nice and smooth in overdrive. Good luck!
Old 06-07-2004, 10:19 PM
Slade901's Avatar
Slade901 Slade901 is offline
Banned
Re: Re: 1994 Olds Cutlass Supreme problem
$300 ?
That's a lot for me.
You can get yourself the GM Top End Cleaner for about $5 (usually available at GM Dealerships) or get SEAFOAM Motor Tune Up for about $5 (usually available at NAPA).
I would however replace the PCV valve if it has not been changed for a long time. You can search the web and type "PCV Catch Can". It is designed to trap the oil from the air/oil vapor before going into the intake. Oil lowers the Fuel Octane Level and causes knock. The breather hose side of the PCV system is suppose to suck air in but pressurein the engine causes air/oil to come out instead of the breather hose and introduce it to the intake (lowering the fuel octane level). Oil in the intake causes carbon build up and gunk in the intake manifold and clogged up sensors.
Old 06-07-2004, 10:21 PM
Slade901's Avatar
Banned
Just make sure you that the spark plug wires are separated from each other with a spark plug wire separator. Make sure that each spark plug wires are not rubbing the engine block and use some tie wrap to move the spark plug wires away from the engine block.
Old 08-12-2004, 11:50 AM
Viper99991 Viper99991 is offline
Send a message via Yahoo to Viper99991
My car is doing the same thing i replaced the egr valve and it was fine for a week then it did it again now i know what it is you guys helped alot deep up the good work
