Old 04-01-2004, 03:01 PM
shirleyj55 shirleyj55 is offline
Unhappy 92 cavalier fuel injector problem
92 cavalier fuel injectors are leaking...we have replaced o-rings on all 4 injectors and they still leak...could the fuel pressure regulator be the problem?...need quick answer...working on friends car as a favor and need to get it back to him...
Old 04-03-2004, 12:31 PM
bigdaveangell bigdaveangell is offline
Re: 92 cavalier fuel injector problem
if the fpr diaphram is torn that could be the cause. It could also be the injectors
Old 04-04-2004, 11:39 AM
Three_Fingers Three_Fingers is offline
Overly high fuel pressure will seldom cause an injector to leak.
I've run them up to 80 psi without so much as a drop.
Take them out and hang just the ends, one at a time in a cheap ultrasonic jewelry cleaner filled with fuel injector cleaner for awhile-you'd be surprised at the crud that falls out.
Then put 'em back with new o-rings and yer all set.
New O-rings will only cure external leaks-ya need to clean 'em to stop the internal leaks.
fuel pump or fuel injector problem princess887 Focus | C Max 10 08-23-2012 07:21 PM
help! fuel injector problem Suzannes Caravan | Voyager 9 11-07-2009 02:06 PM
cavalier fuel injector pops out after shut off engine shenen Cavalier Problem Diagnosis 12 08-09-2009 02:20 PM
98 pathy fuel gauge problem akaesha Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 03-28-2009 09:35 PM
Help Needed applies to `96 Cavalier fuel injectors crystalpistol916 Cavalier 0 10-24-2006 06:30 PM
