Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 04-01-2004, 02:41 PM
OneGT OneGT is offline
Angry Air Bag Codes
I have a 94 Mustang. I accidently left the key turned in the on position and ran the battery down. The next day the air bag light came on. It flashes 5 times with a pause than 2 times, this process repeats several times then the light stays on. I found online that the 52 code means Backup Power Supply/Voltage Boost fault. How is this fixed? And is it expensive to fix? Thanks in advance. Linda
Old 04-02-2004, 12:07 AM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: Air Bag Codes
if you pm me with your e-mail i'll send you the procedure to fix it.
Old 04-02-2004, 07:08 AM
Re: Air Bag Codes
amac, would this be the procedure to fix it? A gray connector located under the glove box" Trouble Code Clear". which contains circuit 631 and 57. After starting the vechile and the trouble code blinking one time use jump wire to short Circuit 631 and 57. Found this procedure online but email me to let me know if this is correct. [email protected]. Thanks amac
Old 04-02-2004, 01:21 PM
Re: Air Bag Codes
i think that just clears the code you need to find the problem first. i e-mailed you the flow chart.
Old 08-25-2004, 12:02 PM
Focused1 Focused1 is offline
Amac,
-Same happened to me - battery drained, code 52 (voltage boost fault) has been flashing since.
-Could you please e-mail procedure to me? Can't find any info on how to troubleshoot this anywhere.
Much appreciated.
[email protected]
Old 12-10-2004, 04:22 PM
Last Time Last Time is offline
Hi I have a flashing light for the air bag too, would you mind PMing me the procedure too? Or if it's not that long just post it up so people don't have to ask for it.
Thanks!
Old 12-10-2004, 04:31 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Re: Air Bag Codes
Thanks!
Last Time, AF has rules about bringing up old threads. I can understand why you brought this one up but I never see Amac in here you'd probably get a better response from him/her through a PM. If you do get the instructions send them to me so I can permantently post them as a tech article. But PM him for the instructions, I'm gonna close this thread.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
1998 Ford Ranger Air Bag Code 27 edlmmx Ranger | Courier 64 08-17-2013 01:13 PM
Air bag code 44, Windstar 96, 3.8l kafkacell Windstar 0 09-07-2010 08:56 AM
1996 Suburban air bag system ground 1993Suburban Suburban 1 07-05-2009 09:50 AM
air bag code ? speeding turtle Taurus | Taurus Wagon 5 01-10-2008 01:00 PM
Closed Thread
