Old 04-01-2004, 06:04 AM
builder77's Avatar
builder77 builder77 is offline
Bondo
Can you use Bondo on a plastic kit?
Are there any drawbacks to it?
Will it shrink?
What do you guys use?
I'm going to be adding a body kit and am trying to figure out how to fill and smooth some transitions.
Thanks
Chris
Old 04-01-2004, 01:21 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
The only problem with bondo body filler is the fact that it doesnt stick to plastic. It wont eat the plastic at all because it doesnt stick.
Can a mod please move this back to the regular Model forum?
-Mike
Old 04-01-2004, 01:24 PM
builder77's Avatar
Re: Bondo
Thanks for the info...there was to be a picture of the project to this point thats why it was in this forum.
Old 04-01-2004, 03:06 PM
Vric's Avatar
Vric Vric is offline
Re: Bondo
yes bondo will work
I used it before I switched to Tamiya
only problem is the putty crack very easyly if it's too tick (ok for filling, not for moding )
you can check the Integra hood on my web gallery, it'S the only bondo work i did.
Old 04-02-2004, 09:32 AM
mike@af's Avatar
Re: Re: Bondo
Originally Posted by Vric
yes bondo will work
You must have been using spot glazing putty. That is for filling small tiny holes in the Bondo body filler. The body filler is hard to crack, in small amounts its flexible.
I am using Bondo Bodyfiller on my Project Roadster, I can twist the side panels a little with out it cracking. Bodyfiller is made for large jobs, and is a lot stronger.
-Mike
bondo Dx18704 '88 - '91 Civic | CRX | Wagon | Shuttlee 11 12-06-2002 11:06 AM
New bondo? Dark Syde Racer '88 - '91 Civic | CRX | Wagon | Shuttlee 3 11-29-2002 04:06 PM
bondo markpa Exterior | bodykits | Lighting 7 04-17-2002 08:19 PM
Bondo Tominos Exterior | bodykits | Lighting 2 02-17-2002 12:19 AM
