Old 04-01-2004, 01:29 AM
BOOTY023 BOOTY023 is offline
Banned
Question mixture problem
its a d16y5 thats the hx engine in a 96' civic.
lets see where do i start, it is running very rough and started while i was driving. sometimes will start (roughly) and others won't. im getting spark to all my plugs and i can smell the fuel, pretty rich, when it will run, im thinking a mixture prob.
also i have a short air intake and it will make a wheazing sound so i took off the filter and only then could i hear clicking inside the intake i haven't changed the timeing belt for as long as ive had the car(2yrs) and it has 110k on it. could it be that? and, is the clicking sound valves hitting the pistons, or is the clicking normal?
Old 04-01-2004, 04:42 AM
liquidflame8 liquidflame8 is offline
Re: mixture problem
don't know what the problem could be but it sounds like the noise you're hearing is just valve train noise? no reason there should be clicking besides that.
Old 04-02-2004, 07:25 PM
Tranzlogic Tranzlogic is offline
Send a message via AIM to Tranzlogic
Re: mixture problem
that is a common valve noise, you can just hear it alot better with a bare intake pipe. umm its not your T-belt cause that has nothing to do with A/F ratio and mixing issues..altho with 110k YOU NEED TO GET IT DONE ASAP, if she goes your out a motor! To the mixing problom it cuold be an array of things sometimes simple, sometimes not....if your sure its running rich, try adjusting your throttle body could be as simple as that..cause if its rich that means your not getting enough air so the problom is there somewhere ....we can figure it out
Please Help!!! Fuel Mixture Problem... kaiost Focus | C Max 34 03-18-2010 01:37 PM
Rich up your mixture serge_saati Windstar 4 08-31-2009 09:54 PM
Fuel air mixture problems??? possibly timing?? Demon_Crest General Discussion 10 02-01-2008 06:46 PM
86 3.8l fuel mixture problem virtual_starwind Ranger | Courier 1 11-17-2005 11:02 AM
