Old 03-31-2004, 10:30 PM
mjacks24 mjacks24 is offline
3000gt plain to vr-4 rear drive block off
ok you guys i have been told i can put the vr-4 motor and tranny in my plain gt but that i would have to purchase a block off the make it only fwd. i have also been told this will burn up the viscous clutch in it. my question is, is this possible can i block it off and if hte clutch burns up will this just make the rear wheel section not work or will the tranny be useless after this happens....... if i cant do this i may have a vr-4 tranny for sale in order to buy a sl...... ok one more thing will the vr-4 motor bolt up to a sohc tranny ive been told the blocks are the same and only the heads are different. if you ahve any info i would greatly appreciate it.
Old 03-31-2004, 10:56 PM
Igovert500's Avatar
blue + red light magnet
Re: 3000gt plain to vr-4 rear drive block off
You're gonna need more parts than just the motor and tranny. To quote SilverStealth from a prior post:
"Hey, SpeedFreakSteve on 3si.org http://www.3si.org/forum/showthread.php?t=198122 is swapping his SOHC for a TT, plus he's changing over to AWD. He's documenting the whole thing, he'd be a good guy to talk to."
Also, I found a TT conversion bible on 3si.org
http://www.3si.org/forum/showthread.php?t=205455
hopefully these will steer you in the right direction.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 03-31-2004, 11:55 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
I dont know the spacifics, of the swap. But if you want to use the vr4 trans pull the VCU out and have it welded so it wont burn up.
