Old 03-31-2004, 09:44 PM
mike123 mike123 is offline
engine swap?
ok so my engine right now isnt runing too well and i got a 305 from a 91rs in my garage , would there be problems with the wiring harness if i do the swap , do i need to swap computers cause one is carb other is tbi?
what would i need , i also noticed the air conditioning pump is located on the other side and small stuff like that
Old 03-31-2004, 09:47 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
Re: engine swap?
what are you starting out with?
Old 03-31-2004, 10:03 PM
Re: engine swap?
305carb is in right now but it has some major problems so iw as gunna swap it for the 305 tbi it was just a nicer engine
*edit* on another note, there taking down the forums?
or what are they talkin about?
Old 04-01-2004, 04:16 AM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: engine swap?
hardware swap will be easy, just take out the old engine, swap over all the hardware, put the new one in. when you talk computers, i assume you are keeping the TPI setup, you will need the computer, wiring harness, and all the sensors to make it work. it might be easier just to use the short block of the TPI 305, and put the carb intake on it. but whichever will be a pretty straitforward job. the fuel injection swap will simply take more time.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 04-01-2004, 03:46 PM
Re: engine swap?
indeed...
