Old 01-08-2002, 11:55 PM
brians97accordSE's Avatar
brians97accordSE brians97accordSE is offline
Unhappy tranny probs
whats up, i need somebody to help me out, here's the prob, every now and then my rpm's jump about 1g and come back and settle, ok, it's been like this for a week, well the other day, for some reason, my car would act as if it's in neutral and just rev up, i have an automatic so it seems and feels really weird, ne wayz, the other day it just like, stopped engaging in any gear, so i stopped flipped the hazards and shut the car off, 15 min later i started up the car and it drove fine, whats wrong with this dang thing, i know i need to get it checked but i need some reasuring advice so i don't go shoot myself, jk, but seriously, if ne one knows about tranny's and their problems tell me, and tell me if it'll be cheap to fix,thanx
Old 01-09-2002, 02:38 AM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
check your vacuum lines coming off the plenum. make sure they're all hooked up. also ensure your idle air control valve is functioning and coolant lines tot he throttlebody arent clogged, and the throttlebody is clean and free of foreign objects.
Old 01-09-2002, 09:17 AM
hondaman-iac's Avatar
hondaman-iac hondaman-iac is offline
Send a message via AIM to hondaman-iac Send a message via Yahoo to hondaman-iac
like drift said check your vacuum lines, then the idle air control valve is good. I duuno what head you have on it but on the f22a1 there is a way to adjust that from the rpm adjusting screw on the tb.
hondaman-iac @ HondaStyle
92 ACCORD LX -- powered by a blown F22A1
Current Mods:
*rear lower tiebar
*AEM CAI
*Koni Yellow Struts
*Ground Control coilovers
*Energy suspension bushing kit
*front upper strut bar
*rear upper strut bar
PureHonda member since April 2001
Old 01-09-2002, 12:27 PM
thanx
thanx for the imput guy's i'll check that out and see if "i" can fix the problem, if not i'll have honda fix it for me,oh yeah by the way i have an h22b2 engine
Old 01-09-2002, 02:32 PM
drift's Avatar
Re: thanx
H22B2? never heard of it. maybe you mean F22B2.
Old 01-09-2002, 05:45 PM
Unhappy bad news
i took the dang car up to honda today, and got a call, the tranny is out and it'll be the end of february to get a new one in, what bullsh*t, so i'm ordering an aftermarket tranny, and drift, if i had the car right now i'd check, but, i'm 99.9% sure its' h22b2, i dunno, u could be right, i'll check when i get it back
Old 01-09-2002, 07:46 PM
JasonAccord98LX's Avatar
JasonAccord98LX JasonAccord98LX is offline
Send a message via AIM to JasonAccord98LX
what kind of car do you have brian? you never told us.
-Original PH Member-
Registered in May of 2001
'98 Honda Accord Sedan 2.3L VTEC 4cyl 5-speed
Generic Cold Air Intake
205/60/15 Bridgestone Potenza RE950's
Save the Oompa-Loompas.....a site I helped create
http://www.oompa-loompas.net
Old 01-09-2002, 08:43 PM
sorry
i drive a 1997 honda accord special edition 2 door coupe, i'm pretty positive from many times i've worked on my car that it says h22b2 on it, but i could be wrong
Old 01-09-2002, 08:49 PM
I believe that "H" motors are found mainly in preludes and that all accords that still have the original motor in them are "F" motors. I could be mistaken though.
Old 01-09-2002, 09:00 PM
well i could be mistaken but when i get it back i'll tell you guys for sure, i'm pretty sure it's an h22b2 thouogh, oh well, i'll see when iget it back
:smoka: maybe thats why the thing hauls ass, it's an automatic but keeps neck and neck with vtec's:smoka: maybe someone fucked with the car
Old 01-12-2002, 03:03 AM
twizzaut's Avatar
twizzaut twizzaut is offline
mine has been doing the same thing. its seems like it does it mostly when im at higher speeds. i was on the interstate about a week ago and my car just wouldnt go anymore so i put it in neutral and reved it up and put it back in drive and then it worked again. its been in the shop twice and the dude said that its never done it when he has drivin it. at least i know what it is know. now its time to swap it to a 5 speed
HöÑÐã§ 4 Lïƒê
