Old 03-31-2004, 06:39 PM
88 trazer 88 trazer is offline
Angry TBI 2.8 won't start
I have an 88 s-10 blazer 2.8, it was given to me for parts. So far I have changed: new fuel pump in tank,new module in dist.,swapped in a known to be good ECM,swapped in a known to be good(from good running 2.8)entire throttle body. Still, it wont start on it's own,but starts after putting approx. 1 teaspoon of gas down tbi. It runs like a new engine, idles fine. Performance is fantastic. Anybody have an answer or suggestions? Thanx for any response !
Old 03-31-2004, 09:05 PM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: TBI 2.8 won't start
check the fuel pressure. it might be bleeding off through the regulator or back through the fuel pump after the engine is off for a while. does the pump turn on for a few seconds when the key is turned to run?? if not check the relay. does it restart when the engine is warm? will it start cold if you crank it for a while??
Old 04-05-2004, 08:23 PM
phill84 phill84 is offline
i would say the fuel pump is not working . i say this because i have a 350 5.7 tbi and mine was doing the same thing and changed the fuel pump and never had the problem again
