hello everyone,,,,,have a question,,my traction control has been kicking on even on non-slippery dry pavement..the light comes on (traction control active) then you hear the traction control kick on..as i mentioned,this happens even on dry pavements,even at low speeds..any ideas??? thanks
Re: traction control ????
what is the condition of your tires and are they properly inflated 30psi to 35 at the very most,a good way to check tread depth is to take a penny and stick it into the tread abes head first, if you can see his hair the tire is worn beyond its effectiveness
have you changed your brakes lately?
[On his running for California Governor] It's the most important decision I've had to make since 1978 when I decided to get a bikini wax. -- Arnold Schwarzenegger Politics is not a bad profession. If you succeed there are many rewards, if you disgrace yourself you can always write a book. -- Ronald Reagan "I wrote a book" --Bill Clinton |
Re: Re: traction control ????
Re: Re: Re: traction control ????
Bad wheel speed sensor? Carefully unplug from the backside of the hub and clean with an aerosol solvent and add some dielectric(silicon)grease to the connector and re-attach. If it still doesn't work, you will need a brake system(ABS/TC)diagnosis and decide what it's worth to you to have these systems operational. It probably will be expensive to fix but remember, it could be a life and death decision.
Quality isn't expensive, it's priceless. |
Re: Re: Re: Re: traction control ????
Couldnt you turn the TC off until you have a chance to get it fixed? At least then it wont bog you down.
I'm not sure where the VSS is on Auroras, so I will sit back and see if someone esle knows
1997 Aurora "Aurora Snow" 250++HP 4.0L Modified Aurora V8 w/Autobahn Performance On Deck: RSM intake, RSM 80mm TB ![]() Administrator, www.oldsmobileforums.com Administrator,Aurora Club of North America Administrator, www.bonnevilleclub.com Adminstrator, www.ontariobonnevilleclub.com Coming Soon |
The wheel speed sensors are integrated into the wheel hubs. They didn't sound too hard to replace, but again- you have to decide if it's worth it to you. You'd have to search previous posts for prices. I can't remember.
Well I bought my car last summer. In the fall I started getting intermittent anti-lock and trac lights til eventually they stayed on.
The other day I hit a pretty good pothole. I was like ouch!!! Ironicly I noticed there after that the warning lights don't come on anymore lol and the trac on/off button is working again. Definitely sounds like a wheel speed sensor connection issue that I'll look into once it warms up. I would suggest, like Indy said, everyone check and clean the connections to the wheel speed sensors. Probably solve 95% of the Anti-lock Trac issues |
You know, I decided to dish out a ton of money when I bought my car and fix my traction control. Mine ended up being the pressure control valve which was $700 or so. And I have not ran into one situation since I got it working (about 2 years now) that I have ever needed it. The only time it ever comes on is if I am on a patch of ice and the only thing it does is alert me that it is slippery and doesn't allow me to do anything crazy like stop too fast. But anyone with common sense knows not to slam on the brakes. When I hit ice, I can feel my car start to slide off the road then I hear the traction control come on and it feels like it pulls me back a little. But it isn't anything I couldn't gotten out of without it. If it goes bad again, if it is a $10 fix, then I'll fix it. But if it is another $700, then I am going to remove the dash and remove the traction off and active lights!!!
I have an 95 olds aurora with 160,000 miles and the traction light has been coming on for sometime now and when the light comes on I can be on dry surface or even when I hit a little bump. My question is why when the light comes on the car like loses power and when you push the gas pedal to the floor the car does nothing, it has no "get up and go". Please respond if you have an answer. Thanks
Sorry but please check the date of the thread. This one is almost 3 years old and we prefer they are not resurrected. Feel free to start a new thread addressing your issue or question. Thread has been closed.
