Odd rattle
Sometimes when I start from a standstill I hear a light rattle noise. This happens when I'm letting off the clutch and applying the gas. It sounds metalic and coming from the engine bay area. I don't feel anything missing or slipping. I just want to make sure this isn't anything bad. Has anyone experienced this? Or know what might be causing it? Is it serious? Thanks.
************************ 2001 Honda Prelude SH DC Header 3" Intake with K&N GReddy Exhaust Unorthodox Racing Pullies JET enhanced ECU 10.3 OBX Plug Wires |
Re: Odd rattle
check your heat shield of the header. that sounds similar to what i had.
Re: Odd rattle
That's been removed. But it does sound something like that, at least from that area.
Any other ideas out there?
Re: Odd rattle
Nosie from inside the car can be hard to know where excatly they are. I had a rattle metal to metal when i accelrated. I didn't know what it was. But i just put on a bolt on exhaust and they is a heat sheild for the cat. I tighting that up and the nosie went away. SO you could check that.
Because i head the nosie from the back of the car and the cat is underneath me so you never know good luck
1992 Honda Prelude SI |
Re: Odd rattle
the heat shield on your cat might have actually shaken loose off the bolts (happened to me), just look under the body.
PS: ignore if you have removed your cat :P
Not-named-yet: 2011 Hyundai Sonata SE w/Sunroof and Nav in Iridescent Silver Blue Pearl Claudia (traded-in): 2003 Mitsubishi Eclipse GTS: Pioneer Speakers All Around, Kenwood MP3 Deck, Clarion Equalizer, Boss 4ch. 800W amp, 2 Dual 12" subs with Dual 500W amp, XM Roady2 R.I.P. Jessica 1997 Honda Prelude: AEM CAI - Exedy Full Face Organic Clutch - XACT Streetlite 12.5lb flywheel - DC Sports Short Throw Adapter |
My 92 had the catalytic converter was rattling from inside. It was a metalic/vibrating sound, and would occure when I let off the throttle. My 92 is an automatic. I checked everthing before I found it. Good Luck.
