Old 03-31-2004, 01:15 PM
k911sc k911sc is offline
stock 97 brake pad replacement
I just bought a 97 civic lx and it needs front pad replace. I had the wheel off and could not determine how the pads are to be replaced. I would imagine one of the caliper bolts would have to be removed and then rotate the caliper back off the rotor. In that process I would need to loosen the 2nd caliper bolt to allow for it to come back off the rotor.
Am I on the right track here? Please advise. Thanks in advance for any insight you might provide.
Toby
Old 03-31-2004, 03:16 PM
96HondaCivic 96HondaCivic is offline
When you are looking at the front of the rotor, their are 2 bolts on the back of the caliper. You can either remove both, or the top only, or the bottom only. When I change my pads i take out the top bolt and fold the caliper down(make sure to remove the pin that holds the brake line to the strut). I got a 96 civic lx. You will have to push the piston back in with either a C-Clamp or something else. I usually use a C-Clamp. Hope this helps.
*- '96 Honda Civic Lx 4 Dr Auto -*
*- CAI 2.5in w/aem bypass -*
*- Invidia High Performance Cat-Back Exhaust -*
*- Suno Hyper Ground System -*
*- Front Upper & Rear Upper Strut Bars -*
*- Dc Sports Rear Lower Strut Bar -*
*- Tom's Lowering Springs 1.5in -*
*- 16X7 Konig Blatants w/ 215/45 Falken Azenis -*
*- Power Stop Slotted rotors -*
*- G-Force 5 Points Harnesses(Only using 4 points) For autocross -*
Front Brake pads replacement olopezm Grand Prix 8 11-02-2010 11:52 AM
Front Brake Job - Replace Rotors? buickultra2000 Park Avenue 3 02-09-2010 07:11 PM
Brake Pad replacement Problems seanzi Maintenance 7 06-02-2001 02:24 AM
