My gas pump went out yesterday and i fixed it. Now when I use the blinkers to turn there is a quick buzz and then the blinker stays on until I let off the break. Again it works fine until the break is applied, then there is a quick buzz that comes off the electirc box that controles the blinkers on the fuse pannel. I am trying to figure out why this is happening. I replaced the box on the fues pannel and the new one will buzz the same as the old one. Could the towing company broke this somehow? I left the hazard lights on and the battery died by the time the truck got to my house. Any ideas what this is. I was thinking some kind of short in the break lite switch on the break pedal? any info would help.
thanks |
Re: 97 k1500 Slverado blinker buzz
check all your fuses, sounds like a blown fuse/feedback problem
you might also want to try the relays under the steering column, there are I think, 3 blinker relays, 2 for turn signals and one for hazards, they are up under where they read the diagonistics, my reccomendation is to swap them around if they are the same, and if you swap them and it fixes it, you know that it's bad, good luck!!
Help ME!, what was it????????
my siver ODDO does the same thing . brake pedal makes it slow down but always clicks and buzzzes! thanks you . Karl |
