Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 03-31-2004, 11:47 AM
mikek mikek is offline
Angry van runs 2 mins. then stalls,map replaced still stalls
I have just rebuilt the 350 in my van I believe everthing correct as far as cam timing , dist timing goes . my problem is that the vacuum hose routing diagram is missing I am not sure where the hoses should go and the local chevy dealer says he doesn't have books on anything this old . help !!!!!!!. Van is 1989 got a code 33 and have replaced MAP sensor no change, however if Map sensor hose is disconnected van will run maybe 4 mins. and then quit. Recently copied the VECI label off another van of same year seems like all the vacuum plumbing was correct same problem exists!!!! HELP ME...
Old 03-31-2004, 05:38 PM
JusGene JusGene is offline
Re: van runs 2 mins. then stalls
You don't mention much about the vehicle (doesn't have any books 'how old'?).
You can get a Chilton manual pretty cheap and it should be in there. I posted '97-3500 Bad morning start' and haven't gotten too many answers yet, but Fuel pump caused similar problem for me.
