Go Back   Automotive Forums Car Chat > Cars in General
Old 03-31-2004, 08:35 AM
jj72ny jj72ny is offline
Send a message via MSN to jj72ny Send a message via Yahoo to jj72ny
krylon fusion problem
I have painted the trim in my car with krylon fusion following the manfac. spects I washed them down with an amonia wash 50/50 water
and i get small places that the paint dose not stick to is there something elts i can do ? do i have to strip the paint that i have on allready off?
thanks in advance for anyones help
Old 03-31-2004, 10:37 AM
camaroincal camaroincal is offline
Send a message via Yahoo to camaroincal
Are the places its not sticking plastic?
Old 03-31-2004, 12:25 PM
yes all are plastic it sticks in some spots and others it won't on the same pice I think my problem may be old armorall but not shure I thought the amonia would work like the can said but after several washings with it 50/50 and all twice 100% amonia i have still had no luck
Old 04-09-2004, 08:34 AM
snowboarding_girl snowboarding_girl is offline
Send a message via Yahoo to snowboarding_girl
Try using a primer like adhesion promotor by duplicolor under your paint
Old 04-09-2004, 09:18 AM
Re: krylon fusion problem
p.s.
lightly sand before you primer.
Old 04-10-2004, 08:46 PM
i will try thatalthough i have put most of the car back together. krylon fusion is "supose to" need no pr :lol2: ep or primer :lol: ya right
Old 04-13-2004, 03:21 PM
00_GS 00_GS is offline
Send a message via AIM to 00_GS Send a message via MSN to 00_GS
I have actually used the Krylon Fusion in my Eclipse GS on my plastic parts, and it hasnt done anything like that to me! I used no primer, and i didnt even use amonia to clean it! Also, i did use a paint brush to paint it by spraying a little into an old baby food lid and then got it onto the brush and painted what i wanted... that actually worked very very well, and it looks really good right now! I am planning on doing more this summer with the Krylon, b/c im changing my entire interior from tan to black and green... so i have a lot of work ahead of me, but im gonna do it! Good luck and i hope what i have done helps you!
Old 04-14-2004, 06:11 PM
hay thanks i'll try that so far i have tryed everything that was rec. but nuthing has worked ecepionaly well
Old 04-19-2004, 11:29 AM
bryanbrutherford bryanbrutherford is offline
krylon fusion contains methylene chloride, which bonds directly to certain plastics that are solvent bondable. If the material is nylon then the fusion doesn't work, if the material is previously painted then then there is a barrier between the plastic and the new paint and will not work properly.
steel wool everything before you paint
Old 05-26-2004, 08:55 PM
MarlBoro MarlBoro is offline
A real good solvent ya might try is MEK (meythl ethyl keatone)sp?
Read good things bout cleaning with it before using krylon fusion on a PC mod forum.
Old 06-07-2004, 02:56 PM
ShaolinMassa ShaolinMassa is offline
I used the krylon fusion also, its good in most places, sometimes (rarely) it wont stick as good as you want it too. Here is what I did to get it to stick good. Everything must be really clean...first sand the plastics with a 300 to 600 grit sandpaper...next use rubbing alcohol on a clean cloth to wipe the parts off...keep using the alcohol on the cloth until you see no more dirt (or residue from the sanding) coming off on the towel...let it dry...then paint away...
Old 06-07-2004, 06:11 PM
SickVette SickVette is offline
Send a message via AIM to SickVette Send a message via MSN to SickVette Send a message via Yahoo to SickVette
The biggest problem with painting plastic is the build of dressings (armor all and such). Those products...espcially silicone will not allow the paint to stick. If you have already painted the part and the paint is coming off in spots...the new paint will not stick to those spots either. Unless you give them an through cleaning. I recommend the dish washer if the parts will fit. The parts will come out like brand new and clean of any dressings. Bryan is correct...Fusion is designed to go directly onto the plastic and no primer. Remember your finish underneath is what is going to determine how good your finish on top is. Anything I paint the final coat of primer gets wet sanded with 600 then base coats.
1999 Corvette coupe 600rwhp and way too much stuff to list everything here.
Audio Pioneer AVH P7500 DVD w/xm
2 PG Ti 600.2
1 PG TiDEQ
Stinger battery,alternator,wire,cap,fuse blocks
1 JL 12w6v2
1 7" monitor in rear
MB Quart 8" 4" and tweet in each door
Custom fiberglass,plexiglas, and aluminum amp rack
carbon fiber sub enclosure
Old 06-09-2004, 09:15 AM
Sanding will definitely help, i use rubbing alcohol to clean the parts after sanding because degreasers leave a film that is hard to get off and the paint wont stick to it...
Old 06-12-2004, 09:23 PM
HondaOz HondaOz is offline
after u sand it with the 600 grit, u should wash them again right? then after that u should apply the paint coats, but one thing though, once u apply the paint, if its krylon, does it need a primer?
Old 07-14-2004, 04:13 PM
Vinny03 Vinny03 is offline
Send a message via AIM to Vinny03
i used krylon fusion to paint my door panels and it looks good but its still tacky and its been about 36hrs the only thing the weather is crappy but all the other parts i paint are dry can someone help
