Old 03-30-2004, 10:28 PM
dsmer gsx dsmer gsx is offline
Exclamation I need help with my 16g???
Hey,
Can any one tell me where I can get some bolts for the coolant lines on a 16g to bolt up to a 1g eclipse. I bought a 16g turbo and it came with out bolts. I've been looking at local hardware stores to find 14mm fine threaded bolts. Well the biggest they have is 12mm. What my plan was is to find bolts that fit and drill a hole down the center on the lathe. Then drill one into the side on the drill press. That was the way I planed on doing it. But if anyone can give me ideas on where to buy some of those, or if I can buy them form someone who has extra. Can you Please let me know...
Thanks,
Scott
Old 04-01-2004, 02:05 AM
soyee7's Avatar
soyee7 soyee7 is offline
Banned
Re: I need help with my 16g???
take them off a 1g turbo at the junkyard, or order them from mitsubishi
Old 04-01-2004, 10:27 AM
kjewer1 kjewer1 is offline
AF - Advisor
Do you mean the bolts that hold the turbo to the manifold? IF so, use ONLY mitsu bolts for that. And be sure to also order the 2g style cup washers to keep them in place. Lock washers will NOT work. If you dont believe me, come look at my car. I have 1 bolt holding the turbo on, and thats the one with the 2g cup washers The other vibrate out before the thermostat opens...
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 04-06-2004, 10:29 PM
No. I am talking about the bolts that hold the water lines. The ones that are on the 1g turbo are too small. Or are you talking about off of a 14b. The bolts won't fit if it is off of a 13g. They are too small. But I could check with a 14b!
Need HELP... Thanks for the replies..
Old 04-07-2004, 02:22 AM
AF - Advisor
Yes, the 13g uses smaller banjo bolts for some lines. Its a TDO4 center, not a TDO5 like 14b and up. All of the bolts from a 14b are interchangeable with 16g.
Kevin Jewer
Old 04-07-2004, 11:24 PM
Sweet. That is exactly what I needed to Know. Know I could just look for the banjo bolts off of a 14b.
Thanks!!!
Old 04-09-2004, 08:06 PM
Well, my bolts just came in from the hardware store and I fabricated my own banjo bolts, cause NOBODY had any around here. So I just got my turbo hooked up and my engine is going in soon. Thanks to all who replied...
Scott
