Go Back   Automotive Forums Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > General Discussion
General Discussion All general comments or enquiries go here. Website, club oriented, or general Skyline banter.
Old 03-30-2004, 10:27 PM
Ebola 33-t Ebola 33-t is offline
Cables under passenger seat
Hey all. Was wondering what the cables under my passenger seat are. There are 2 cables which go into a thin braided line. The braided line comes out underneath the car where it has been cut somehow, and skims along the ground. My reverse lights dont work either so i presume it has something to do with that. Any help on how to rewire it would be appreciated.
Cheers
Old 03-31-2004, 03:08 AM
GTES-t's Avatar
GTES-t GTES-t is offline
The braided line (that's cut) was your cat's temp sensor. You most likely have a de-cat test pipe that doesn't use the exhaust temp probe.
Your reverse lights are wired to the trans. and should be on the forward switch (if you have a manual) on the driver's side. It should wire into a connector on the driver's side of the engine bay.
1990 Skyline GTE/S-t 4 Door Updated 6 Mar
Swapped out RB20E with RB20DET
Trans converted from Auto to 5-Speed...
Now with SR20DET 5-Speed
Installed Type M 5-lugs and brakes, R32 GTR rims and 2-Dr rear end (Tail lights & bumper)
1994 Isuzu AMU
US Spec Amigo with JDM Isuzu MU (Mysterious Utility, as it's called in Japan) nurf bars and hatchback style hardtop.
Old 03-31-2004, 06:37 AM
Cheers GTES-t
Thanks for that. It kinda makes sense that the cable is sitting loose, as there is no cat on the 33. If i do end up getting a high flow cat for it, then would i need to reconnect the cable or jsut leave it off?
Also i found the reverse cable which connects to the gearbox. It is the top most connector on the gearbox, and was damaged somehow. I have reconnected the damaged cable and suprise suprise, reverse lights came on like magic.
Cheers again.
