Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 01-08-2002, 09:45 PM
dominate9 dominate9 is offline
Send a message via AIM to dominate9 Send a message via Yahoo to dominate9
Bec Tech or Tokica?
I have a 97 Honda Accord EX on 225/40/18. I want to lower my car some and still have the stock/factory smooth ride. I've been hearing good reports about combining ground control coilovers with Tokica "Blue" or Illuminas. Then I read something about Bec Tech Suspension. Are Bec Tech Struts better than Tokica "Blues" or Illuminas"Blues". What would be my best bet for lower my car?
Old 01-09-2002, 01:33 AM
texan's Avatar
texan texan is offline
Writer Mod
What are you looking for besides a lower ride height and a smooth ride?
'03 Corvette Z06
'99 Prelude SH
Old 01-09-2002, 08:12 AM
That is all I am looking for: lower height, smooth ride, little to no bouncing (preferrably NONE). I just want to be able to drop a couple of inches so my ride looks nice and then be able to raise it back up whenever I need to. Where I live has a lot of hills and high raises, so I'll be varying my height very once in a while. When I go back home, it'll be dropped as far as possible.
Old 01-09-2002, 08:25 AM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
I would recommend Koni Yellows or Tokico Illuminas - you can smooth out your ride to your liking with the adjustments on the top of the shocks.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 01-09-2002, 08:35 AM
Will I be able to reach stock height again? Will I need to have specific coilovers to work with the struts or will just any coilover do?
Old 01-09-2002, 09:25 AM
Kohhal's Avatar
Kohhal Kohhal is offline
Well I had the Bec-Techs on my Civic with Eibach Pro-kit springs. They were comfortable cruising and lowered about 2" but they bounced on dips which got a bit dangerous on the back roads here. It was cos it was lower than what the springs should have been I think(1.3"). HTH
A curse upon you Oliver Cromwell
You who raped our Motherland
I hope you're rotting down in hell
For the horrors that you sent
To our misfortunate forefathers
Whom you robbed of their birthright
"To hell or Connaught" may you burn in hell tonight
Old 01-09-2002, 05:11 PM
1993HondaCivic 1993HondaCivic is offline
hey civsiracer, what kind of shocks do YOU have?
Old 01-10-2002, 01:03 AM
Jims 86LXI HB Jims 86LXI HB is offline
Well that all but confirm's what I heard about the Bec-Tech's. I heard that all he does is shorten the strut casing and the piston rod and NO
RE-VALVING. You'd think if he's got the talent to whip them up in his garage that he'd have the brains to know if you increase the spring rates you need to increase the compression and rebound rates. Or you get to experience what is quoted above. Sadly some people have that going on and don't realize it, they just think the car rides so nice and comfortable, gawd WAKE UP!!!
Old 01-10-2002, 07:52 AM
Civic Mod
With coilovers yes you should be able to go up or down depending on your liking. The only problem with coilovers is that when you redadjust them you should get an alignment.
Autocross Help Page
Buy my Civic parts!
Old 01-10-2002, 07:53 AM
Civic Mod
On my 1993 Civic I had Tokicos and Skunk2 coilovers. Little bouncy (prolly blew my shocks) but handled nice.
Most of the autocrossers I know use Koni Yellows or MOTec shocks. MOTec is a bit out of my league as they are $1200-2000 PER SHOCK!!!
On my Civic Si I have now I'm going to get Koni Yellows and custom rate ground control coilovers.
Autocross Help Page
Buy my Civic parts!
Old 01-10-2002, 08:26 AM
HONDA_99 HONDA_99 is offline
koni yellows are hieght adjustable also (1"-1.5", depends on car), but koni recommends to use lower perches only with OEM springs.
Power: Denso IK22 spark plugs, OBX Headers, J32A2 Camshafts, CT SC w/HB
Electronics: Apexi VAFC (untunned)
Gear Box: Rebuilt at 53K ml & at 63K ml by Aamco and still
Suspension: Eibach Sportlines, Koni Sport, Comptech Sway Bars & Neuspeed upper strut bar.
Wheels: 17x7 OZ Racing Superleggara & 215/50 Dunlop Sport A2
Brakes: Legend GS 2 Piston Calipers, Goodridge SS Lines, Endless Nova Pads
Old 01-10-2002, 10:18 AM
Does it really throw the alignment off that bad? Why is that? Gettting it aligned could be a bit of a hassle. I'll be high the majority of the time. I'll only have it really low for a couple of days out of each month and during the big holiday breaks.
97 Accord EX Coupe (H22A)
_____________________________
18" Focal SD5
225/40/18 Kuhmo Ecsta Supra (712)
AEM Cold Air Intake
Walbro 255lph Intank Fuel Pump
HP Racing Exhaust
2.25 Custom Piping
Spoon Radiator Cap
Katzkin two-tone Leather
3 JL Audio 10W3s
Kenwood DPX-4020 Double Din
Old 01-10-2002, 01:10 PM
petzride's Avatar
petzride petzride is offline
I hope u don't think raise or lower the car is a easy thing. From my experience on skunk2, it takes time and makes me headache. It is really not something u want to do daily or even once a month. U'll also have to worry about the camer too....
oh..and I see u have 18'' wheels.......
wow...u'll need a set of expensive shocks to get smooth ride.....
believe me~~
FULL OF S15~~
For sale: http://www.automotiveforums.com/vbulletin/t53308.html
Old 01-10-2002, 04:39 PM
believe me~~
The ride is a little rough right now but not too bad. I am planning on getting ground control coilovers and Tokica Illuminas. Previous posts told me that gives a smooth ride. I was told that is isn't too hard changes heights on ground control. Since I have got the 18's", the camber has become an issue for me now. Someone told me that I might ned a camber kit if I am going to lower the fender to the wheel (to cover up the gap). I didn't think the 18's would give lowering problems. Any recommendations on my setup?
18" Focal SD5
AEM Cold Air Intake
HP Racing Exhaust
2.25 Custom Piping
Spoon Radiator Cap
3 JL Audio 10W3s
Old 01-12-2002, 01:06 AM
Oinac Oinac is offline
If you're getting coilovers I suggest getting Koni, NOT Tokico (Blues or Illuminas)... the reason being Tokico doesn't recommend you lowering your car more than 1.5" from original stock height (well for my application and it VOIDs warranty)... this being said Tokicos want to limit how much you lower, while on the other hand Koni will handle drops more than 1.5"... I have Tokico Illuminas right now...
