Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 03-30-2004, 08:16 PM
RedCordCoupe RedCordCoupe is offline
Send a message via AIM to RedCordCoupe
97 Accord Bottoming Out?
Hey I'm brand new to this site and was wondering if someone could help me. I just lowered my 97 Accord with H&R sport springs. Don't have new struts on it yet but im planning on getting them soon. Everytime I go over bumps I can hear something in the rear suspension make a clunking noise. I'm wondering if that is the bump stop hitting or something like that. If anyone can help I would greatly appreciate it.
Old 03-30-2004, 08:39 PM
liquidflame8 liquidflame8 is offline
Re: 97 Accord Bottoming Out?
did you cut the bumpstops?
Old 03-30-2004, 09:06 PM
No the H&R info that came with the springs said that for Honda applications the bumpstops should be left alone but I have been hearing different things about that.
Old 03-31-2004, 12:51 AM
BullShifter's Avatar
You should ALWAYS cut the bump stops when lowering. If it's clunking most likely the spring(s) are not set right.
Old 03-31-2004, 06:07 PM
Explain what you mean by the springs are not set right please
Old 03-31-2004, 06:13 PM
spooleffect's Avatar
spooleffect spooleffect is offline
Send a message via AIM to spooleffect
Re: Re: 97 Accord Bottoming Out?
Springs like H&R increase the spring rate propotionally to the amount the car is lowered so the spring will compensate for the lack of stock wheel travel with an increased spring rate. Cutting the bumpstops is a bad idea because it can allow to much suspension compression that could allow components to contact each other.
Are you sure your hitting the bumbstops? It could just be a loose part, a mis-set spring like jackasssi mentioned, or it might be that your dampers are not stiff enough so your suspension is being allowed to compress to easily.
Old 03-31-2004, 06:53 PM
http://www.binghamtonlife.com/manual...s/91-18-25.jpg
Look at the spring perch, see how it's not the same height all the way around? Your spring profile should follow that contour, it's like that on top too.
Old 03-31-2004, 07:46 PM
Hey thanks a lot. I'll go ahead and check that out to make sure it's set right and maybe that will fix my clunking sound.
