How to remove 1997 VR4 Bumper
Does (or did) anyone know how to remove the front bumper on a 1997 VR-4? Is this a body shop thing or is it removing bolts etc... I want to replace the bumper with a nicer one..any suggestions? Thanks!
Re: How to remove 1997 VR4 Bumper
remove you side markers(blinkers), there should be one screw at the back of each, and they should come off pretty easy.
remove your headlights, 3 bolts under the hood, one behind the side markers. remove thge front inserts to your wheel wells. remove all the bolts you can see on the top that go through your bumper do the same to the bottom on the inside of the wheel wells remove 5 bolts from each side, 2 will be vertical and 3 will be horizontal. that should be all, and it should pull right off, if not you missed some |
