Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 03-30-2004, 06:09 PM
netmaniapc netmaniapc is offline
Help with location of oil level sensor?
Could someone tell me the general location on engine for the OIL LEVEL SENSOR, 3.8 engine, V-6 , Pontiac Gran Prix , 1999
Thanks Mark
Old 03-30-2004, 06:14 PM
Ripn12s's Avatar
Ripn12s Ripn12s is offline
Send a message via AIM to Ripn12s
Re: Help with location of oil level sensor?
Mark,
If i remember correctly the sensor is on the passenger side of the engine. I think you should be able to see it from above, if not remove the splash guard in the fender and you should see it there.
Old 03-30-2004, 06:16 PM
Ripn12s's Avatar
Wait, I might be thinking of the oil pressure sensor.
Maybe someone else can confirm this
Old 03-30-2004, 07:26 PM
GTPgirl's Avatar
GTPgirl GTPgirl is offline
Send a message via ICQ to GTPgirl Send a message via AIM to GTPgirl Send a message via Yahoo to GTPgirl
The oil level sensor, at least on the '97 I had, screwed into the side of the oil pan.
GTPgirl
Black 1998 Camaro - currently driving
Black 1999 Grand Prix GTP - burned March 2008
Plum Crazy 1970 Dodge Challenger - work in progress!
Old 03-30-2004, 08:21 PM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
Roger GTPGirl, Ripn12s you are talking about the OIL pressure sensor that is on the passenger side facing the firewall and you can see it from the side if you turn the tire all the way to the left. From that I hooked the oil PSI dial installed on the LOTEK, the oil pan does have the oil level sensor facing to the front of the car.
Old 11-11-2007, 05:11 PM
bjaymo3 bjaymo3 is offline
Send a message via AIM to bjaymo3
GTPgirl is right. I was just under my car this past week and removed it as I thought I was going to change the oil pan gasket. Changed my mind about the gasket as I didn't have time to DISASSEMBLE THE FREAKING ENGINE!!
2002 Grand Prix GT 3.8 V6
1998 Dodge Grand Caravan 3.3 V6
1998 Chevy Blazer 4wd 4.3 V6
Old 11-11-2007, 05:14 PM
By the way, I think I broke one wire on the sensor connector and I now get the "low oil level" light when first starting the car. If I turn the car off and then back on, the light is gone. I'm thinking an under-car soldering job.
And the sensor is on the side that faces the radiator.
Old 11-11-2007, 06:28 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Sorry but please check the date and do not resurrect old threads. This one is over 3 years old. Thread closed.
Timeslip 08/12/06
AF Community Guidelines
95 Lumina oil level sensor saxonmor Lumina 4 01-25-2011 11:27 AM
Does the oil warning light have an oil level switch? dieter Caravan | Voyager 5 08-29-2009 03:36 PM
Oil level sensor location jessman1128 Grand AM 3 03-10-2006 09:16 AM
oil level sensor leaking oil? mhall02 Montana/Montana SV6 2 01-01-2006 06:36 PM
Need a little help with locating IAT sensor in cougar 99 4 cyl 5 spd Mareshalu Cougar 8 12-23-2004 02:07 AM
Closed Thread
