Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 03-30-2004, 05:34 PM
Seadragon Seadragon is offline
Angry changed plugs now have check light
I have a v6 2002 rodeo with 61,000 miles I changed the Spark plugs and now have a check engine light on all the time, and when accelerating the light flashes.
I installed Bosch plugs is this the problem?
I pluged in my friends code reader and it says plug misfirer.
Whats going on?
Help....
Thank You
Old 03-30-2004, 06:11 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
put the Bosh junk in the garbage that is your problem install Nippendenso plugs
Old 03-30-2004, 07:38 PM
salb3039 salb3039 is offline
Re: changed plugs now have check light
Or use NGK. From what I can tell, most Rodeo guys use NGK. I am putting some in this weekend.
Old 03-30-2004, 07:50 PM
rodeo02 rodeo02 is offline
Poke around this or the other isuzu sites. For the 2000-2003 3.2/3.5L (not sure about the 2004's), if you use anything other than denso/nippondenso spark plugs, you will get a check engine light because of the sensitivity of the ignition systems on these trucks.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 03-30-2004, 11:31 PM
amigo-2k amigo-2k is offline
Isuzu Guy
+2000 Isuzu's and bosch plugs just don't jive. Check my FAQ link below for some plugs that will work.
-Ryan
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 03-31-2004, 05:18 PM
Thumbs up
Thanks for your help I ordered the Denso plugs from St Charles today....
SeaDragon
Oil Check Light FordBoss88 Caravan | Voyager 3 01-18-2010 08:56 AM
92 Accord shift cable change, now with engine check light!???? jstarnes Let's get Technical! 1 03-29-2009 12:18 AM
Trooper 94-changed alternator now have no lights and power Webraft Trooper | SLX | Bighorn | Wizard 18 11-09-2007 12:23 AM
Changed FPR now having white smoke out of exhaust??? XSTINCT-04 Aurora 2 05-14-2007 06:16 AM
changed spark plugs, now car won't start... sixofone Camaro Discussions 4 12-28-2003 04:52 PM
