Old 01-08-2002, 08:47 PM
praxis praxis is offline
Will a B16 head fit on a D16 block?
B16 head/D16 block...
What all would be needed to make this Frankenstien?
I know that Sparq asked a similar question but I think that this one may need attention, too.
PraxisPerformanceAutoworks LLC High performance autoparts & accessories.
________________________
sales and specials...Konig wheels, Accmat carpets, Thermal exhaust, DragunFire mufflers
_____________________________
PraxisForums...informative information
PraxisRacing is sponsoring. click for more info.
see PureHonda in its original colors-->
Old 01-08-2002, 08:57 PM
91zc 91zc is offline
No it will not work. Sorry but only d series heads will bolt onto d series blocks and only b series heads will bolt onto b series blocks. HTH
91 civic 4dr
b16a
14.8@94
Old 01-11-2002, 07:33 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
its not nearly worth the amount of money needed to mill and bore and cut and weld and do whatever to match those two up.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 01-11-2002, 07:38 PM
jimmyfunk's Avatar
jimmyfunk jimmyfunk is offline
Send a message via AIM to jimmyfunk
just use the first letter of all the honda motors as a simple guide......B will only fit B.....D will only fit D.....etc.
GO BIG PAPA!
aim: XjimmyfunkX
Old 01-12-2002, 07:33 PM
91b16sedan 91b16sedan is offline
Yeah I was going to say what everyone else said.
B16a
Other Mods
14.8 @ 94 mph
Old 01-12-2002, 09:31 PM
VTEC_boi's Avatar
VTEC_boi VTEC_boi is offline
Send a message via AIM to VTEC_boi
That's a good rule to go by..but like always there are exceptions.
One example being the ZC motor. Which is compatible with teh D16Z6 head.
But then again..the ZC is known by a D-series code in other countries........
"Son, your eyes look a little red there. You've been hittin the Vtec haven't you? Alright, stand on one foot, touch your nose and say 'Third Rocker Arm'".
Original PH Member (Reppin' for original PH'ers!)
www.lunspeed.com
www.jdmcivic.com
www.sweetcarz.com
Old 01-12-2002, 09:41 PM
Whtehnda93DXSdn Whtehnda93DXSdn is offline
Send a message via AIM to Whtehnda93DXSdn
Yeah the ZC is just the D series but for our overseas patrons...
it would be nice if you could do that ad just have each built. but would be to much $..:frog:
another good honda site:
www.civicland.com
Old 01-12-2002, 11:48 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
eh wrong!
Apprently the two head gaskets are quite differnt, and altough the swap can be done it does require some machine work to both and head and block to line everything up.
Old 01-16-2002, 02:11 AM
pvang31019 pvang31019 is offline
it's not impossible...nothing a little duck tape and JB weld can't handle
Old 01-16-2002, 02:39 PM
sparq's Avatar
sparq sparq is offline
AF Premium User
Send a message via AIM to sparq
Re: Will a B16 head fit on a D16 block?
No I didnt ask about dropping a B16 head onto a D16 block... I was asking about dropping the D16 head onto a D15 block
AF's Official Asshole
RIP AUNIE
Old 01-18-2002, 05:32 PM
hrdcorezc hrdcorezc is offline
I'm not really sure this is possible. I don't believe that the oil and coolant ducts match up between the two. Besides, why on earth would you want to swap a SOHC head in place of a DOHC head?
time slips do the talking, bullsh*t runs the marathon
Old 01-18-2002, 06:14 PM
VTEC_boi's Avatar
Well...first of all I wasn't really saying a ZC head will work with a D16Z6 block or vice-versa. I was saying parts for a D16Z6 would work on a ZC. (such as the GReddy turbo kit)
Though it is possible with some machine work like Moppie said.
Damn you mop! always makin' me look stupid
It's a hell of a lot easier than a B onto D swap.
Why SOHC on DOHC?
For VTEC of course :hehehe: . Or going vice-versa with a ZC DOHC head on a D16Z6 block.
Hey Moppie - did ya get any of those jobs?
www.lunspeed.com
www.jdmcivic.com
www.sweetcarz.com
Old 01-18-2002, 08:40 PM
Yeah, you can use certain parts made for the D16Z6 on a ZC, like the turbo set up because the exhaust manifolds are interchangable. But the heads are not interchangable no matter how much machining you do. The oil and coolant ducts are in different places. Even though they are both D series motors (the ZC is just a JDM D16A) the oil and coolant duct configurations are completely different. Mainly because the heads mated to these blocks are designed differently. And the D series block has evolved considerably since it's inception in the mid 80's.
Old 01-23-2002, 08:03 AM
CivicRacerX's Avatar
CivicRacerX CivicRacerX is offline
Send a message via AIM to CivicRacerX
Hey, just wanted to thank you guys, because I was about 10 seconds away from posting the exact same question that you started with when I saw this thread. The D16 in my 99 EX is ok, but I just began to wonder if I could get a B16A top end and get real VTEC, instead of its SOHC little bitch sister.
What cars had D-series engines with DOHC Vtec, other than the Civic Si,
that I could steal from and put onto my wee motor?
96 Honda Civic Daily - H22 Swap
82 Renault R5 Weekend Runner - Nearly Stock
83 Renault R5 Track Car - 13:1 CR, Archer Cams
Old 01-23-2002, 08:44 AM
None of the D series motors were DOHC Vtec. You will have to swap in a b series motor like the b16a2/3 or B18c1 to get the twincam Vtec setup.
91 civic 4dr
b16a
14.8@94
