86 has a few Problems
Just bought a 86 pickup that has a few problems.
First, when driving down the road I hear a clicking noise that is faster the higher my speed is, and is completely gone when I stop. As I slow down the noise gets slower. Any ideas? Second, I replaced my air pump a few days ago, and in order to do that I removed the alternator. Well since then, my battery doesn't charge all the time. Sometimes it will charge, other times it won't. When it doesn't charge, the voltage meter is at about 10 volts and goes up to about 13 volts when I hit the gas so I know the alternator is working. It also goes up to 13 volts when in park. Any ideas? Thanks, Nick
A driver drives, but a drag racer lives Mods: NOS Powered NOS 3rd Brake Light Cutout NOS Front Grill Clear Plastic Cutouts Custom Painted Interior 250 Watt Thump! Amplifier 600 Watt Electra Box (Two 10" Subs) Neon Lighting Around Subs Neon Lighting Under Car Flip Flop Trunk Spectre Air Filter Shaved Badges Audiovox 6" LCD Screen Interact 5" LCD Screen EuroDezigns Xenon Lights Dominator R16 Tires Black Ghost Flame Decals Pyramid Door Speakers |
Re: 86 has a few Problems
Not sure about your charging problem but the clicking sound you are hearing is more than likely a bad u joint.
charging problem sounds like a loose belt.
this is late but check your tires for a nail or screw in the tread. it will click everytime your tire rotates.
replace the ujoints and tighten the belt!
Check your speedometer cable. That may be your clicking noise. As for the Altenator/Charging Problem follow the wires back to the Starter and look for a broken or loose connection.
