Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 03-30-2004, 11:06 AM
805ace 805ace is offline
Question Nitrous set up
Im gonna make my engine set up for nitrous and i was wondering what i would need to do to my engine for a pour nitrous set up, and what kind of nitrous i should use i am kinda stuck on Zex and Venom. I have a 95 honda dx.
Standard or stock whatever you call it you shouldn't have any of that sort on your car...
Old 03-30-2004, 12:17 PM
XXConvict XXConvict is offline
Send a message via AIM to XXConvict
Re: Nitrous set up
probably zex since that motor is kinda weak
Old 03-30-2004, 09:16 PM
quick95civic quick95civic is offline
how much power are you looking to get out of the kit? You should atleast upgrade to stainless steel valves, next if you are looking to get alot of power out of it you should start looking at a different type of piston and possibly rods. Aside from the engine if you want to get alot of power you will need to upgrade the fuel system too.
Old 03-30-2004, 09:35 PM
liquidflame8 liquidflame8 is offline
Re: Nitrous set up
rods fo sho. you should look into that new zex kit that has the injector in the head of the intake filter.
Old 03-31-2004, 12:28 AM
Neutrino's Avatar
Neutrino Neutrino is offline
Yaya Master
Send a message via AIM to Neutrino
well i won't say anything about internals since i don't know that much about your engine or how high of a shot you want to run but as far as nitrous kits the venom vcn2000 should be the best dry:
http://www.venom-performance.com/nf/...2000.htm#v2000
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination
Old 03-31-2004, 11:04 AM
Re: Nitrous set up
i want to run a 50 shot
Old 04-03-2004, 11:48 PM
Demoncvc Demoncvc is offline
Re: Nitrous set up
50 shot is reasonable. See how much fuel you have goin to the engine and if you get a fuel pressure regulator, you should be able to go 75 if you get more fuel. And BTW dry kit is ballz, wet kit all the way buddy, you would be much happier with it.
Old 04-04-2004, 06:59 AM
Neutrino's Avatar
Yaya Master
Re: Re: Nitrous set up
its true a dry kit can be very dangerous if not properly tuned. However an excellent nitrous kit like the vcn-2000 properly tuned will be much better than a wet kit.
The problem with wet kits is there is a difference between the flow of nitrous and fuel, this will cause different a/f ratios among the cylinders with the first running the leanest and last richest, in many case it can cause backfire.
there is a guy in the local autox chapter with a 5.0 that had a backfire on his wet kit and now he also swears only by a dry
here is a more complete explanation:
The second type of nitrous kit is the "wet" style of kit. These kits include carburetor plate systems and add nitrous and fuel at the same time and place (normally 3-4" ahead of the throttle body for fuel injected applications or just under the carb as with plate systems). This type of system will make the upper intake wet with fuel. These systems are best used with intakes designed for wet flow and turbo/supercharged applications. The reason for this is the fact that fuel flows differently than air or nitrous. This difference in flow characteristics can lead to distribution problems and, in some cases, intake backfires. Intakes designed for wet flow (such as with carburetors) cause much less separation of the nitrous/air, and fuel. Because modern fuel injection intakes are designed to flow air only, they have tighter turns and a more compact design as a result. Thus, they generally do not make good candidates for wet flow nitrous systems.
(\__/)
Old 04-04-2004, 01:21 PM
Good point about the wet kit. But also take into consideration the technology that NX has developed in the wet kit. It has a system the delivers a very good hetergenious mixture of air and fuel. There are other wet kits that do well. If your argument is contingent upon one partys product then maybe you need to do some research on some other companies as well. I will research venom. When it comes down to it if A. it isn't tuned properly or B. is abused by the user, that equals a backfire. NOS is touchy stuff sometimes .
Old 04-04-2004, 10:55 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: Re: Re: Nitrous set up
The same can be said for a dry set up as well. The intake manifolds on most hondas do not distribute the nitrous evenly, which will cause the cylinders to be lean and rich. But for a 50 shot he would be alright with a wet kit. Like I always tell evrybody above 50-65hp go direct port, that is the best way to setup a wet kit. Also wet kits requre alot of tuning also, a device such as a Jacobs nitrous mastermind will help greatly, I have one it will allow you to adjust the fuel soleniod inrichment in relation to the bottle pressure etc. But you have to know how much to richen or lean it out, that is were experiencecomes into play LOL.
Old 04-05-2004, 07:35 AM
Neutrino's Avatar
Yaya Master
Re: Re: Re: Re: Nitrous set up
I'm sure companies are aware of the problem and have taken steps to compensate. My comment was general not aimed at a single company. its a physical fact that a gas will have very different flow charactesitics than a fluid and its hard to compensate for that.
The final outcome will be determined by your manifold design: in some cars wet kits will work great in other they can mess up your engine.
I beg to differ. I never heard of a dry setup to cause that problem.
A dry setup just ads, to the normal air coming from the intake, another gas with a higher oxigen content plus the added endotermic effect of an expanding gas. So the nitrous from a dry kit will just arrive in the manifold just as normal air and be treated as such.
On the other hand a wet kit(not direct port) is more akin to adding a small carburetor before a manifold designed to accept and distribute only air and then mix it with fuel. not incoming gas/fuel mix as in old school engines with carbs.
(\__/)
Old 04-05-2004, 03:34 PM
PoisonFangs PoisonFangs is offline
Banned
Send a message via AIM to PoisonFangs
Re: Nitrous set up
I have the venomVCN-1000 and i like the setup, I have not sprayed yet cause i just finished putting it in but we will see.
Old 04-05-2004, 10:10 PM
Neutrino's Avatar
Yaya Master
cool tell us how it woks when you finish installing it.
Btw I'm not that familiar with the vcn 1000 what is the difference between it and the 2000?
(\__/)
Old 04-05-2004, 10:45 PM
Banned
Re: Nitrous set up
it is basically the same thing, as far as basic set up goes, but the vcn2000 has the option to program setups on the computer using a disc and then puting the disc into the computer moduel on the nitrous system to really fine tune it. the vcn1000 does not have that so basically its the setup just like the zex. I have everything installed i just need to get the bottle filled and go to the track. We are going in about three weeks so i will let you guys know.
Old 04-06-2004, 07:41 AM
Neutrino's Avatar
Yaya Master
cool than for the info
(\__/)
