Go Back   Automotive Forums Car Chat > Lincoln > Continental
Old 03-30-2004, 10:02 AM
TTUNNELL TTUNNELL is offline
Question SQUEALING BELT NSY & LOW COOLANT
My 99 Cont'l Makes A Constant Squeal. Plus The Low Coolant Level Light Comes On About 1 Week After Replenishing. Does This Indicate More Than A Loose Or Worn Belt? What Could It Be And About How Much $$$ Is It Going To Cost Me? Hint: Does Not Squeal As Loudly When Stationary.
Old 04-06-2004, 07:59 PM
Towncar's Avatar
Towncar Towncar is offline
Re: SQUEALING BELT NSY & LOW COOLANT
Squeal can be alot of things.
1) Bad Belt, mis-aligned belt, loose belt.
2) Bad, Belt tensioner bearings.
3) Bad, Alternator bearings.
4) Bad, Battery causing alternator/belt overload.
5) Leaking coolant on the belt, causing slipping/screaching.
Maybe it's not engine related:
1) Disc brake, pad wear sensor rubbing on disc.
With all the engine related noises you can use a listening device (like a stethoscope, long screwdriver, etc) to find the source. Changing engine rev's while inspecting should help narrow the field.
How many miles are on your Conti? Is this one a 4.6L V8? You don't see any flluid leaking or spots where you park? How's the engine running, real smooth or a bit rough? How's the idle, smooth? Is there any sign of coolant in the oil?
-Steven
1996 Town Car, Cartier
Old 04-12-2004, 12:06 PM
Thank You So Much. I Found Out That The Water Pump Was Leaking On My Serpentine Belt. I Replaced The Pump And Everything Is Working Noise Free! Thanks Again.
Old 04-12-2004, 02:16 PM
Towncar's Avatar
Re: Re: SQUEALING BELT NSY & LOW COOLANT
Cool !!
Glad to hear it was something relatively inexpensive, and easy to diagnose..
Sometimes these things can be elusive.
-Steven
