Old 01-08-2002, 07:42 PM
D16 V-TEC's Avatar
D16 V-TEC D16 V-TEC is offline
Send a message via ICQ to D16 V-TEC Send a message via AIM to D16 V-TEC
B16A swap into 88-91 CRX
I've got a few questions concerning this swap. First ones concern the car itself. Is the 88-91 (4th?) gen. CRX F.I. in all models or just in the Si like the previous gen? If so, would I be able to use a DX or HF with the same ease as an Si? Did the chassis change from ?-87 to 88-91? If so, which gen is easier for the swap. I have found a cheap 88-91 so I am planning on using that for B16A if I wont have a hell of a time getting it in there . Now onto the engine. What are the differences between the JDM B16A from the SiR 1 and the USDM B16A from the 'Teg? If anyone from CT has experience with the JDM B16A, do you know if it will pass emissions? Thanks folks!
Perky Nana Boy!
I am Jack's biting sarcasm.
1990 Honda CRX Si
I poach Pandas and pimp Sheep!
Old 01-08-2002, 09:53 PM
MLodsin MLodsin is offline
Send a message via AIM to MLodsin
Crx's suck D16, get a METRO. J/K I love those little cars. Good luck
1995 Honda Civic DX-Still with me
1995 Honda Civic VX-Future B18c Engine Recipient
Former PH Member
Old 01-08-2002, 10:02 PM
I think you woud have problems with the engine mounts in this crx.
THis site will have good information for you:
http://hybrid.honda-perf.org/tech/4gtech.html
Good luck on the swap.
Former PH Member
Old 01-10-2002, 07:43 PM
Phat_Si's Avatar
Phat_Si Phat_Si is offline
Send a message via AIM to Phat_Si
I've got a Vtec Solenoid for a B16. $75 Let Me know.
Old 01-11-2002, 03:42 PM
Phatwhippin_CRX Phatwhippin_CRX is offline
Send a message via ICQ to Phatwhippin_CRX Send a message via AIM to Phatwhippin_CRX Send a message via Yahoo to Phatwhippin_CRX
www.phatwhippinCRX.20m.com
Tells you step by step how to do the whole thing, I did the swap myself in a day and a half... taking my time drinking lots of beer. haha
1989 DOHC VTEC CRX Si
C'mon, it's only a Honduh...can't be fast!
I AM the Anti-Rice!
Swap info, Turbo tech, and naked chicks!
Old 01-13-2002, 09:08 AM
5_LiTeR_EaTeR 5_LiTeR_EaTeR is offline
Send a message via AIM to 5_LiTeR_EaTeR
Mlodsin... What they are saying in that tech site is that you can't bolt the motor up with the SI-R or stock motor mounts. What they were simply saying is that the only way to bolt it up is with a Bolt in motor mount kit or a weld in Kit. I bought my motor mounts for the left and right side for 200. They were telling me it uses the stock rear mount. I am still doing my swap so I will see how it bolts up in the back. I heard its a pain in the ass....
Old 01-14-2002, 08:10 AM
Dude the SiR mounts will NOT work.
You NEED a kit. Screw welding, it will break.
www.hasport.com
Get the mounts, or deal with the problesm you're gonna have.
Also, dont forget the 90 Integra rear motor mount bracket, you need it.
I AM the Anti-Rice!
Old 01-14-2002, 03:04 PM
D16 V-TEC's Avatar
But a ZC will bolt directly on with stock mounts, correct?
Perky Nana Boy!
1990 Honda CRX Si
Old 01-14-2002, 05:24 PM
Yes it will... I would get a ECU with it though because the stock CRX ECU tremendously holds back its power potential with a rev limiter, etc...
Old 01-15-2002, 01:59 AM
Straller Straller is offline
Ehhh
You will like your CRX to have a B16. It's pretty basic besides you need to get a mounting kit. My tires have troubles gripping the street when I race and sit there and spin. You'll want to throw on some cheater slicks at the same time as you drop the motor in.
Old 01-15-2002, 05:34 PM
Well yeah it would be great to have a B16 but you have to understand that not everyone has the money to do so. A Zc will bolt in but with a B16 you will have to do more than just a motor mount kit. you will have to run 4 wires to the ECU, get the motor mounts, shift linkage and also get Axles. There is alot more work involved with the B16a but the results are very rewarding. You can go with a ZC and buld on that.... or you can start off doing more work and spending more money but you start off fresh with 160 HP! Your choice!
Old 01-15-2002, 07:53 PM
D16 V-TEC's Avatar
Just because of money issues, I am going with the ZC and will slowly prep it and turbocharge it. Thanks for all your help guys .
Perky Nana Boy!
1990 Honda CRX Si
