Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 03-29-2004, 10:15 PM
Sk8erprelude Sk8erprelude is offline
Question H22 redline
Hi guys,
I am installing a Jdm h22 in my prelude(use to have a f22), can someone tell me the redline on this engine? I am installing a aftermarket tach and need to set it up. Some sites say 7200 rpms and others say 8200 rpms.
Thanx
Old 03-29-2004, 10:49 PM
ShoofIsLudin ShoofIsLudin is offline
Re: H22 redline
Originally Posted by Sk8erprelude
Hi guys,
Thanx
7200 good luck with the install
Old 03-30-2004, 01:18 AM
SenseiAccord SenseiAccord is offline
Re: H22 redline
It depends which H22 u got and where it is from. Most peak out at different RPMs. Not sure if redline is all the same but ill tell u the peak HP RPM on the different h22s
*97+ H22a type s (JDM) peaks at 7200 RPM
*97-98 H22a1 & 99-01 H22a2 peak at 7000 RPM
*97+ H22a non type s (JDM), 94-96 H22a1, and 92-96 H22 (JDM) peak at 6800 RPM
Old 04-01-2004, 09:05 AM
Re: H22 redline
Thanx for the info. The engine is from a 4th gen. prelude from Japan. I need to motify the throttle cable plate because it came out of a RHD car and some other minor things but it should work out.
I will try to post pics on the swap if anyone wants to check it out.
Old 04-05-2004, 02:01 PM
Re: Re: H22 redline
I swapped out an h23 to the jdm h22...the fuel line will most likely need to be replaced because they're not located in the same place.
Old 04-05-2004, 07:02 PM
northtexasskater northtexasskater is offline
Re: H22 redline
mine is 7200 the same as the chevy bretta I used to have with the GM quad 4 engine. It had 185hp and 150 lb-ft
Old 04-07-2004, 10:33 AM
Re: H22 redline
Hey Shoofisludin,
Can you give me more info on the fuel line replacement, did you make one or purchase one?
Any pics?
Thanx
Old 04-07-2004, 12:47 PM
AcesHigh's Avatar
AcesHigh AcesHigh is offline
Prelude Guy
Send a message via AIM to AcesHigh
Re: H22 redline
As he said... the JDM h22 fuel lines come out on the opposite side. He just swapped the fuel rails from his old h23a block. I don't know if the f22a works the same way or not.
1993 Mazda Rx-7 Touring
Ricer Extraordinaire
Old 04-07-2004, 01:11 PM
Re: Re: H22 redline
Actually aces that sounds like it would've worked but thats not what we did with mine. On mine we just added an extension to the fuel line so that it would reach. It works just fine and no problems so far....but I was strapped for cash in the process of my swap. If you want to do it right just re-do the line instead of ghetto rigging it like i did. another thing with the h23 -> h22 swap, the exhaust is going to have to be connected...the h23 header to exhaust is about 6-8 inches long than the h22 so you'd have to have an extension welded to piece it together. also make sure all your cable are whole and not cut like mine...kuz it's just a pain in the ass. And more than likely you're gonna have a distributor problem. Something w/ internal and external coils...however i could be wrong bekuz i'm not familiar with the f22. I'll see what i can do about some pics to help u out, but i can't make promises
Old 04-07-2004, 01:59 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Re: H22 redline
Ace htf are you a mod already
