Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 03-29-2004, 08:37 PM
00trdtaco 00trdtaco is offline
major help on lift got ?'s
i have a 2000 tacoma trd and im trying to get a little more clearance to put on some 32's. I had a idea that I would put on two inches or so on a coil spacer and a add a leaf in the back and that would be cheap easy and effective. I recently went to a four wheel parts store and they said that the spacers would require me to get new shcks and struts and that it wouldn't fit 32s and also my stock rim would not be able to hold any larger size tire than the stock 31s. I have been getting mixed messages with internet stores and friends and these four wheel part places. My funds are limited and want to know if the spacers and 32 inch tire idea would work. i heard i could retain my shocks because i just purchased monroe sensatrac shocks and struts. help please
Old 03-30-2004, 01:25 AM
superjoe83 superjoe83 is offline
Send a message via AIM to superjoe83
Re: major help on lift got ?'s
spacers and add a leafs will get you enough room for 32x11.50"s as far as shocks go, you WILL NOT need new or longer front shocks, because they are made only to let the control arm drop so far to prevent cv/ball joint binding, as for the back, you can try it with the shocks you have right now, it will be ok for street use but the shocks will limit your articulation and will need to get longer ones if you wheel alot. Now, about your wheels, they are fine, my friend has a tacoma with the stock 15x7 alloys running 32x11.50's with no lift, but he also rubs a bit. Hope this helps, Joe
If it aint broke, fix it anyway
Old 03-30-2004, 01:39 PM
dfskinner dfskinner is offline
Joe, he rubs a little when he's turning or all the time?
Dennis
Old 03-30-2004, 02:07 PM
just turning
Old 04-02-2004, 09:56 PM
BlkTTORA BlkTTORA is offline
help on your lift
Get a 3inch revteck. It will clear up to 33's and no worries.
Old 04-04-2004, 04:35 AM
redtoy92 redtoy92 is offline
superjoe hit it on the head! what he said is how it is! red
Old 04-06-2004, 10:19 PM
Shredhead Shredhead is offline
Re: Re: major help on lift got ?'s
I just bought a tacoma 4x4 it's been years since ive been able to afford one (the family thing) I would like to lift it fairly inexpensivly (somewhere around 3 to 4 inches) and I have seen the lift kits that use spacers for the coil springs with an add a leaf or blocks for the rear as well as doing a mild body lift but from what I have read using these spacers could damage the joints and boots, any one have an idea?
Old 04-07-2004, 01:29 AM
Re: Re: Re: major help on lift got ?'s
they do increase the wear and tear on the cv's because they increase the angle on them. but if you get a kit like the one from cornfed you get a diff drop with it that will help out the angle and you will be fine! I would say they make the best spacer lift for the money! if you have the money then a coilover(saws.kings,etc) would be nice! if you don't run over 32 inch tires that is all you need. if you want 33's then a 2inch body lift will be a good idea with it! red
Old 04-07-2004, 07:14 PM
I heard something about the differential drop sounds a little like how a truck with a solid front axle was lifted, the tallest I have seen is the 3 inch spacers but as I said they say you shouldn't go over 2". If I went 3" spacer with the diff drop would that be safe enough? It's been way to long since Ive had a 4X so go easy on me with the next question here, where do You get the cornfed lift kit on line? And what is a (saws.kings,etc) like I said it's been a while so don't tear me up to much.
Old 04-08-2004, 08:32 AM
you will be fine with the 3inch spacer and the 1 1/4 diff drop. try http://www.cornfedsuspension.co-inc.net/ the saws and kings are a way to lift the front but they are coilover shocks a much better ride but the price is much more. http://www.tsliftkitstore.com/produc...t.asp&ID=52553 red
Old 04-08-2004, 04:26 PM
Thanks for the advice, I clicked on the link You posted and came up with errors so I googled and Yahood cornfed but did not see an actual company cornfed. Is cornfed an actual lift or a style of lift?
Old 04-09-2004, 12:50 AM
heres a link that works for cornfed http://www.cornfedsuspension.com/
Old 04-10-2004, 08:11 PM
onemeantaco onemeantaco is offline
I put a 2.5 coil spacer and add a leaf, and a 3" body lift on a 2000 taco ext cab, i have been plowing snow with it for 2 years and havent had any problems with the cv joints
Old 04-11-2004, 09:14 PM
Thanx for all the help I will be doing the cornfed thing with the diff drop as well
Old 08-12-2004, 12:55 AM
hemidog hemidog is offline
so hows the cornfed suspension doing??
