Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 03-29-2004, 02:57 PM
obiwand obiwand is offline
Send a message via MSN to obiwand
Cool 1998 ford ranger xlt
My check engine light came on a while back then went off and now its been on for a couple months, I had the code checked and it says it's p0153 o2 ckt slow response I am mechanically retarded so could someone explain what this might mean ? I have 50 thousand kilometres on this engine i think another code they gave me was IYO31N
THANKS FOR ANY HELP
Old 04-01-2004, 12:58 PM
jt-stl jt-stl is offline
Send a message via AIM to jt-stl
Re: 1998 ford ranger xlt
That code comes up when your pcm doesn't receive any input from the o2 sensor within 2 minutes after starting. You probably need to replace the o2 sensor--which can be a PITA. Has your gas mileage dropped recently? When mine went bad, I could tell I lost about 2 mpg. Is the other code p1031, maybe? P1031 is HO2S Heater Current Monitor Control Circuit Sensors 1, but I don't know of the exact cause for it. It reads that the voltage across the sensor is off. I would replace it.
1992 ford ranger stx cluth question kokopelli85 Ranger | Courier 1 12-26-2009 04:57 PM
98 ford ranger xlt super cab auto trans problems TouchedByAngels2 Ranger | Courier 2 07-16-2004 10:16 PM
1993 ford ranger xlt supercab heyman-80 Ranger | Courier 1 07-16-2004 10:09 PM
1988 Ford Ranger XLT tkaudio Ranger | Courier 2 01-01-2004 09:35 AM
F/S 1998 Ford Ranger XLT cgfb9 Ranger | Courier 0 10-13-2003 03:41 PM
