Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 03-29-2004, 01:11 PM
holywolfman holywolfman is offline
Question Vehicle Speed Sensor- (question!)
I have a friend who owns a 1996 Rodeo, he has been having trouble with no speedo (analog speedo not working)....and has SES light on (PO502- "Vehicle Speed Sensor- Low input")
1) I have replaced the vehicle speed sensor (rear of tranny) due to a "repair" shop exclaiming that to be the problem.
2) After replacing part- (I couldn't erase code since I do not own a scan tool), I noticed no change to speedo as well!! -still inop!!!
3) Can anyone Please tell me the correct diag. path for repairing this code?.... Is the correct sensor to be replaced the one on the rear end: "Wheel speed sensor"? Would this wheel speed sensor have anything to do with speedo operation or is it just reference to RWAL?
Any info will be GREATLY appreciated!
Thanks!
-Nick-
Old 03-29-2004, 10:55 PM
Cat Fuzz Cat Fuzz is offline
Just a thought that came to my mind: Are you sure you got the right thing? "Wheel Speed Sensor" kinda sounds like an anti-lock brake component.
Old 03-30-2004, 06:30 AM
...Yeah- actually I just checked a wire diagram and flow chart at a local library. The speedo circuit is powered by 12v by the "Meter"/30 amp fuse-----> which is sent to the VSS (vehicle speed sensor which is in tail end of trans) and also works (spliced in conjunction) to PCM/VCM (main computer) which I believe sends out a 9v reference signal----> As far as components: It can be either a VSS (sensor) or PCM (power control module) or a fuse (30 amp/ 'Meter'). BUT, It can also be an open or shorted wire somewhere (maybe unlikely) or at a very least (even a bad cluster guage-not registering the speedo!)
...I do not have a scan tool to check voltage or sensor operation (MPH/ vehicle speed) I am thinking (and leaning) towards the 'main' PC (VCM)
ANYONE ELSE RAN INTO SIMILIAR PROBLEM?
* What I can also try is giving the sensor (VSS) a "known good ground"--> Splice a wire into blk sensor wire and clamping it on the chassis or something since I remember checking the diagram and seeing that that wire (blk wire off sensor) is a ground wire and goes directly to ground! [It is not grounded at the PCM per say!]-maybe I have an 'Open' ground wire!]
Thanks again!
-Nick-
Old 03-30-2004, 06:34 AM
Re: Vehicle Speed Sensor- (question!)
BTW: I believe the other sensor (WSS/ wheel speed sensor) which is located on the rear end is for ABS brakes (RWAL) as far as reference ONLY. (telling the ABS module/PC how fast rear wheel is spinning)- I don't think that has anything to do with vehicle speed as far as speedo is concerned!
-Nick-
Old 04-09-2004, 09:44 PM
xxcrowleyxx xxcrowleyxx is offline
apparently there is a speed sensor which should be behind the dash/speedometer..ETC i know since in the last 2 cars i had they were behind the dash.. it should be a small plastic square box with a hole in the middle & a cable(i don't know what u call it) that goes into that sensor to measure the rotation of the engine. if that is defective u get no speedometer reading.
-scott
Speed Sensor spgoethals Taurus | Taurus Wagon 3 04-06-2009 06:35 AM
Speed sensor maybe transmisson???? c_evans1979 Caravan | Voyager 8 03-15-2009 12:27 PM
Vehicle speed sensor question lewenz Windstar 4 02-04-2006 04:01 PM
Question about Vehicle speed sensor cobra148 Grand Prix 6 01-06-2006 06:06 PM
speedometer:odometer cable, speed sensor,vehicle speed sensor johno1 Ranger | Courier 1 10-27-2005 11:53 PM
