Old 03-29-2004, 12:49 PM
MGoBlue102 MGoBlue102 is offline
Question Problems Starting When Warm
Help!!! Before having a new fuel pump installed, I could simply turn the key forward for a hair of a second and my blazer would turn right over and run fine. Fuel pump went bad and I installed an aftermarket (Advance Auto) lifetime warranty product. Ever since installation, I now have to turn the key forward to the accessory position for 5 seconds (listening to the engagement of the fuel pump) then the engine turns over with no problem as long as the engine is cold. Now the problem is when I go somewhere, turn it off for a few minutes then come back and try to start it again. When I turn the key forward this time, usually the engine turns and turns and turns without firing, I have to turn the key backwards and forward 2 or 3 times before it will fire. Could this be anything else besides the fuel pump or do I need to exchange this as a defective product.
Old 03-31-2004, 12:25 PM
Re: Problems Starting When Warm
Surely someone has an answer to this...
Old 03-31-2004, 02:14 PM
ofcmlong ofcmlong is offline
Send a message via Yahoo to ofcmlong
Still sounds like the fuel pump to me. You may want to check your fuel pump relay also. You should hear it click from the glove box when you turn your key. I would get the fuel pressure checked and go from there.
Old 03-31-2004, 02:58 PM
I just bought a fuel pressure guage from autozone, I will have to figure out how to use it but hopefully tonight I can get a reading on the pressure and post more later to see if its normal.
Problem starting latorawilson Impala | Impala SS 8 04-29-2011 03:14 PM
02 Grand Am Hard Start when engine warm. ajbtrugreen Grand AM 3 08-01-2010 01:06 PM
No start, has spark, has fuel, only when warm? anyone? ateball7 Achieva 0 02-14-2009 08:19 PM
2001 Astro difficult starting when warm, OK on cold start?? dhspring M Bodies 10 09-22-2008 12:56 PM
1992 Grand Am problems starting when warm jamec123 Grand AM 11 03-16-2005 05:19 PM
