Old 03-29-2004, 11:34 AM
coloradotaco coloradotaco is offline
Gas odor in '95 GT
When my '95 GT gets hot, there is what I think is a gas odor. I changed the vapor cannister and never top off the tank when I fill it up, it still stinks when it's hot out. There does not appear to be any leaks.
I also get a detonation when it's hot. Could they be related?
I use 91 octane. Only mods are a cat back and K&N filter. Cooling system has been rebuilt so it doesn't run hot.
Any ideas out there?
Old 03-29-2004, 02:00 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
Re: Re: Gas odor in '95 GT
Originally Posted by coloradotaco
I didn't realize this was comedy central.
it's not, really... usually somebody will post something random when they don't have an answer =)
i'd say you shouldn't be using 91 on stock compression. i'm assuming you dont' have a power adder. change to regular 87 and see what happens. that should solve your detonation problem. as for a fuel smell, just because there don't appear to be any leaks doesnt' mean there aren't any. if you can get the car up in the air, check all the lines while it's running to see if you get drips. also, you could have a bad o-ring on one of your injectors (there are 2 per injector) and it's most likely a top one.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 03-29-2004, 11:23 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
There's no point to be running 91 octane on your combo, definitely switch back to 87. Higher octane than needed hurts horsepower and your engine for that matter. As for the heavy exhaust smell, check your EGR. A non-nunctioning or mal-functioning EGR will cause a rich exhaust smell.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 03-29-2004, 11:25 PM
grand_am93's Avatar
grand_am93 grand_am93 is offline
Banned
i think you need new rubber seals
Old 05-20-2004, 04:54 PM
changed the EGR over the weekend. Pinging is gone and it hasn't gotten real hot since but I haven't smelled the heavy fuel odor.
Good tip thanks
Old 05-20-2004, 08:30 PM
351wStang's Avatar
351wStang 351wStang is offline
High HC's?
Old 05-21-2004, 08:54 AM
Its running good on 87 octane also. I am curious to see what kind of change there is in mpg
