Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 03-29-2004, 07:58 AM
condo0000 condo0000 is offline
91 Explorer Engine Shake when switching to overdrive
Hi,
I just replaced the wires, spark plugs and EGR valve on the car. Originally, the idel was very rough, and the car seemed to lack horsepower. The engine would "shake" when I stepped on the accelerator. Now, the problem seems to have gone EXCEPT for when I get on the highway and it shifts into overdrive. As soon as the overdrive kicks in the engine "lugs" and shakes/vibrates. I also seems to loose horsepower at the same time.
Any ideas as to what may be causing this??
Thanks for your help,
Craig
Old 03-29-2004, 09:54 AM
Opera House Opera House is offline
Re: 91 Explorer Engine Shake when switching to overdrive
Overdrive causes the output shaft to turn 33% faster than the motor is. This puts a very heavy load on the engine. Any engine problems will become very obvious in overdrive. It is likely that you still have unresolved engine problems.
Old 03-30-2004, 04:35 AM
srercrcr srercrcr is offline
Turn off the overdrive and drive it to high speed.
If no problems, it could be the lock-up torque converter.
