Go Back   Automotive Forums Car Chat > Plymouth > General Discussion
Old 03-29-2004, 04:18 AM
yasmina yasmina is offline
Wink Laser Idling Problem
I need help. I have a 1992 Plymouth Laser RS. This started happening this week. Everytime the car is at a standstill it stalls. Even if I put the car in neutral, it still stalls out. It stalls out when it's parked and when you stop a traffic light. I've had it at a mechanic and he says it is the AIC motor (stepper motor). I have never heard of this part! I have looked all over the web for this part for my car, but can't find it. Is there such a part for this car? Or is the problem something else??? Any and all help appreciated.
Yas
Old 03-31-2004, 11:49 AM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Re: Laser Idling Problem
Check for an ISC instead. Also check out some DSM forums like www.dsmtuners.com , but remember to search for the answers to your questions before posting a thread.
Kris
2012 Genesis Coupe 2.0t
Old 04-06-2004, 03:12 PM
MrRoscoePC MrRoscoePC is offline
Smile stalling
The AIS (Air Idle Solenoid) is located on the side of the throttle body. The job of this part is to regulate the amount of air that bypasses the throttle plate to control idle speed. If it is only dirty, which is common, then it can be removed and cleaned with an aerosol carburetor cleaner. If the part is defective and needs replacing then you would be better off getting a new one.
The term ISC (Idle Speed Control) is not used with Chrysler vehicles.
RG
Old 04-06-2004, 03:17 PM
Though I appreciate your knowledge of terminology, you are incorrect.
The Plymouth Laser wasn't built by Chrysler, and ISC is the correct term, and will aid him in his searching.
http://www.crebotech.com/
http://members.shaw.ca/dsm.1000q/Engineprimer/
The second link is quite useful.
Kris
Old 04-14-2004, 01:12 PM
True, the laser is jap scrap, assembled in texas. and its not as if there are enough acronyms for the same part in the industry for each manufacturer. sheesh. try asking the chrysler parts guy for an ISC and he'll look more confused than normal.
Old 04-14-2004, 01:20 PM
It was assembled in Normal Illinois along with the Eclipse and Talon.
I HATE dealer parts counters. I asked for a BISS screw and was quoted 800 dollars "because it isn't available without buying the whole intake manifold".
Cost 1.99 at a "in the know" Mitsu dealer.
www.conicelli.com
Kris
Old 04-14-2004, 01:28 PM
At the dealer its all about the money!
